Question about Samsung Washing Machines
No power one of the 2 pc boards is faulty or transformer is faulty
2 Suggested Answers
  • 1121 Answers
SOURCE: Hp Pavilion getting no power after relocating pc.
the Power transformer has diferent outputs, +5V,-5V,3V,12V and so on.., but has a standby output a low power 5v to power button function.
Your PC have Power supply Defective,
so your must find a usual spare power supply on the market, compatibilty as 115V input and more of 350W power, to have stabilty.
Posted on Nov 29, 2009
Sharp dv-rw 260 shut of when playing casette, fuse is ok. No power to start-stop button, cant get casette out, or start player.
Transformer board. Do you have any power after the transformer/transformers?
If so, the board is faulty. If not the transformer is. Either way it's a new board unless you have a good supplier and **** good eyes.
Jan 18, 2012 | Televison & Video
Conveyor belt not working on the image17.5s
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz1 )probably a faulty speed sensor try to adjust firt with the face to the motor. 2) the speed sensor is not plugged in properly tight . 3)also possibly a faulty motor Test for 110 vac.without load. 4)main control board or lower board faulty, try to see if coming 115VAC from transformer. 5) Test the main transformer for primary voltage and secondary voltage 6) Power supply coming from transformer and see if there are some components Ic., resistor, capacitor or diode burn. 7) You must test the tension form Deck belt is about 2-3" for lif, if not Re-adjustment 8) Lubricate the deck belt. See the block diagram for final diagnostic and you will get strong Resultant.
sincerely.
Merry Christimas.
ernesto cuadra
managua,nicaragua
Dec 19, 2011 | Icon Image 17.5 S Treadmill
Goldstar MTD-602
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1)probably a faulty speed sensor fix if all around base in face with otherside motor 2) the speed sensor is not plugged in properly. 3) It possibly a faulty motor control board or lower board 4) main motor faulty see if you test 115VDC for input board + 5VDC for input .5) Test the transformer input and then measure the secondary transformer for input to power supply for 5VDC to lower board or main motor board. 6) tight very well the flexible cord from keypanel to display board 7) tight the connector from display board to main motor board. The error codes will differ between makes and models but could be e1.
see the attached diagram how the main motor controller board has aprox 90% of functions of any treadmill. Now you can get strong resultant for diagnostic the equipemt what is bad.
sincerely. G-d bless you
ernesto cuadra
managua, nicaragua. c.a
Dec 18, 2011 | Exercise & Fitness
I have a Polaroid 40" model number TLA04011C. It is currently at a tv-repair shop and the technician informed me that the problem with the tv is a transformer on the power supply board is out and nee
ShopJimmy likely has the power supply board with the best price, otherwise discount-merchant.com.
However I have one the I am currently looking at where the power supply board was the original issue, and after going over it throughly, the real problem was numerous bad solder joints from the factory. The silver solder is deceptive at times because a joint may look good or passable, but is actually faulty. More often what is seen is called " cold solder joints" where the solder crystalized upon cooling.
Unless the transformer is actually visibly scorched, the transformer may just be suffering from bad solder joints on the PC board, or even on the wires where they attach on the header leads. (This by the way was the main problem on early Macintosh computers having a bad solder joint where the winding attached to the header lead, so this is nothing new)
It does lead to an ugly repair in some cases, but once corrected, it is no longer something to worry about.
If there happens to be a drilled circuit trace- that is probably a factory revision. Try it "as-is" and see if it comes to life.
Dec 06, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Fitnex t60 display says prg bad, what does that mean and how can i repair it
1) You must test first the power supply for +5DC for I.Circuit( Including EPROM, ROM, etc)
2) Test the flexible cable between KeyPanel and display board, and clean.
3) Chechk the connector between Display Board with the lower board(Main Controller Motor)for loose connection, loose wire.
4) Test the transformer controller supplying the 12VCA, to the power supply at the Main Controller Board since this supply the +5vd to the Display Board.
Finally you must have Strong Conclusion if the problem is 1)Display Board faulty, 2) Power supply Faulty, 3) Transformer Controller Faulty 4) Main Controller Board Faulty.
For All test you must use Dvoltmeter.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA.C.A
Nov 21, 2011 | Fitnex T60 Light Commercial Treadmill
The lcd when swicthed on it display for a second and went blank again, but the audion is good
hi,
You have to check the backlight inverter board of your TV. If any one of the chopper transformer ( high voltage transformer) is faulty then the inverter board will consume more current from the power supply. This will sense by the protection circuit and will deactivate the voltage to the inverter board. Some times faulty electrolitic capacitors in the power supply or in the invereter board can can lead to this type of problem. First of all check the electrolityic capacitors. If any one of the capacitors in the power supply or in the inverter board seen budging on the top repace the same. If the problem remains then you have to replace the backlight inverter board.
ok
Jul 04, 2011 | LG 32LG30 32 in. LCD HDTV
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Sound but no picture
you have a inverter problem. 1- the inverter board itself with component failure, possible high voltage transformer. 2- a faulty ccfl. any fault here will shut down the inverter power as a safety percausion.
sending inverter board for repair will only check that board itself is faulty, thus moving on to check CCFL's with in the backlighting of the screen.
Dec 31, 2008 | Akai PDP4225M 42 in. Plasma Television
Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Dec 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
BenQ FP72G+ 17" LCD Monitor NO DISPLAY
The way the circuit works is in a mirror format. There are 2 identical circuits that go to each end of the board.
Be sure to check that fuse for continuity, not just for a second like you normally would, but hold it for a good 10 seconds.
Also don't forget while you are in there it's best to repolace it anyway with an actual fuse. A 3A slow blow ceramic is good for this.
Check the 4 transformers as well, if you notice the top circuit is the faulty one, then check the transformers at the top. The transistors are quite powerful, and normally need something to trigger them into failing. Do the same for the bottom circuit.
This monitor came in 2 formats. One with 4 transformers and 4 CCFL tubes, one with 2 transformers that lead to 2 CCFL connectors powering 2 tubes each (3 wires per CCFL)
When you order the 2SC5707's get extras just to be on the safe side. If it goes again, then turn the monitor off immediatly and check them. It should only be 1 failed again, so just see which of the 2 transformers it was primarily attached to and replace it, or both.
Apr 22, 2008 | BenQ FP72G+ 17" LCD Monitor
Washing Machines Logo
11 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
