Question about Audiovox Prestige Code Alarm Remote Alarm Protx6
Prestige alarm remote # APSO2BT2
The remote acts very strange. When a battery is put in the remote, the green light flashes wildly for about 5 seconds straight, and then it stops working. Also, the valet switch is no longer part of the car. Over the years I have had the alarm, the wire from the switch ripped because it was installed with the wire hanging over the gas pedal. How can fix this?
5 Suggested Answers
logosc75
  • 625 Answers
SOURCE: how to disable or reset a Prestige car alarm.
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Posted on Oct 29, 2010
logosc75
  • 625 Answers
SOURCE: my alarm was working fine
Sounds like the unit may have seized (common occurence with this unit). Disconnect the positive battery terminal, wait ten seconds, reconnect. If you have a security radio be sure to have the code handy.
Posted on May 24, 2011
logosc75
  • 625 Answers
SOURCE: I bought my car used
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Posted on Jul 17, 2011
alicantecoli
  • 22326 Answers
SOURCE: Prestige car alarm, 1991, on a BMW318is 1991. Prevents starting car
follow all the wires from the alarm back to the wiring loom then reconnect the wires that have been cut ,simple but time consuming job and it possible as i have done a few on beemers and these remote start things ,complete waste of time fitting in the first place people seem to think they know it all and listern to the so called experts with their 1950s BBC english and automaticaly assume that because they talk posh they know it all and pay a fortune for junk alarms when a padlock and chain around the steering wheel is a better antitheft device
Posted on Nov 17, 2012
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Alarm remote not functioning properly, no valet switch.
i would think the button is activating the fob, or when you put new battery in is it the right way or you may have pushed something inside and its come lose off the board, it would need opening up and having a look, and testing the switch.
Jun 10, 2017 | Audiovox Prestige Code Alarm Remote Alarm...
My alarm was working fine then one day i just unlocked the car drove then when i tried locking the car with the remote and it didnt work the light that flashes when alarm is on didnt start flashing it...
May 22, 2011 | Brand New Prestige Aps787n Remote Startcar...
My alarm light blinks twice stop then twice and stop its continuous and my alarm shows a picture of the hood and trunk door up. when I press the green button to remote start my vehicle my alarm sounds. I...
The LED blinking twice and, the trunk and hood being displayed on the remote indicates trunk/hood trigger. Now, when you attempt to remote start the vehicle and nothing happens, it's definitely the hood pin switch. By the way, the remote should be displaying "inhibit" as well at this point. Check for the hood pin switch under the hood; it's probably bent downward, not allowing the pin to make contact with the hood when it's closed. If it's a bracket, bend it upwards. If it's a pin, unscrew it upwards a couple of turns so it makes contact with the hood when it's closed.
Dec 12, 2010 | Prestige Remote Start
Need to reset prestige car alarm - going off intermittently
If your alarm is going off intermittently:
It could be the shock sensor; usually located around the steering column under the dash. It is a small black box with two small lights ( one red, one green) and a philips screw used to adjust the sensitivity. Counter clockwise reduces the sensitivity.
It could be an open trigger: door, trunk, or hood pin. If you have a pin in the trunk or under the hood that was added by the installer, they sometimes can be inadvertently bent downward by loading the trunk or, some guy changing your oil. If that is the case, just bend them back upwards until they make contact with the hood/trunk lid when closed and you receive one chirp when arming the system.
Here is a quick way to determine what exactly is causing the alarm to trigger:
After the alarm triggers, disarm the alarm and pay close attention to the LED light. One flash is the shock sensor. Two flashes is the hood/trunk pin. Three flashes is the door trigger.
Oct 06, 2010 | APS787 Prestige Remote Start and Security...
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Audiovox Prestige Code Alarm Remote Alarm Protx6 Logo
175 people viewed this question
Top Prestige Appliances Vehicle Parts & Accessories Experts
xxxxxx xxx
Rocguy
Tim Marx
Tim Marx
Are you a Prestige Appliances Vehicle Part and Accessory Expert? Answer questions, earn points and help others
