On my technika TV menu screen keeps popping up,how can i stop this?
I switch on TV and in about half an hour menu screen appears,goes off then re-appears constantly
  • 80 Answers
SOURCE: Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
Posted on May 21, 2009
SOURCE: Lock/unlock symbol appears in the middle of the screen
hold the menu button between 10 and 20 seconds until the lock changes to unlock
Posted on Jun 14, 2009
BoiseLCD
  • 63 Answers
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Posted on Dec 16, 2009
Warf135
  • 137 Answers
SOURCE: Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
Posted on Feb 23, 2011
SOURCE: I have a nokia E5
I have same problem. I suspect moisture damage or short circuit due to bad build quality.
Posted on Mar 09, 2011
problem seems to be solved,i altered the auto time feature and it settled down
thanks for replying
Bob Hawksby
Mar 31, 2014 | Audio Players & Recorders
Ite mate I have a technika flat screen 32" and I
the output power of your inverter is not constant... it needs constant input...
Apr 27, 2011 | Inverter 1000-2000w Peak Surge Power
Technika LCD26-209
Hi
I have a technika LCD26-209. I have an annoying problem when I try to adjust the volume with the remote control. Nearly every time I do this the tv actually goes into the input selection screen menu & I have to select EXT-2 again to get back to the tv screen I was on.....Any ideas what I am doing wrong?
Thanks
Nov 01, 2010 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
I have Technika TV (model Number 15.4-311) with
  • Remove any DVD in the player.
  • At the blue screen type 9735.
  • A menu should pop up. select region and then select the top option which should be region 0 (0= multi-region).
  • Next select exit setup then power off the tv. It should now play all regions.
I just did this myself so i know it works.
Apr 02, 2010 | Televison & Video
Menu keeps popping up and then goes away
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Akai PT5492S 54" Rear Projection...
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
116 people viewed this question
 Grubhead
Grubhead
