Question about Toys
4 pronged ignition for zee dee 125
New ignition
Will not go into park
Check linkage or cable !disconnect at the trans,and see if you can put it into park by hand that way you will know if it is internal problem or external,could be under the shifter.
Jun 09, 2015 | 1993 Dodge Dakota Truck Tool Box , 93
Login will not work
just use the control+alt+delete. it is a trick perhaps may work
Sep 08, 2014 | Bed Mat Skid Made From High-strength...
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
My 2005 silverado 1500 will not go in 4 wheel drive, I have changed the actuator in the front differential, the light will flash then stays on as if it is in 4 wheel drive, how do I check the transfer case...
Have a friend press the 4wd switch while your under the tran.Then listen to hear if that actuator moves. Make certain that you can not be run over, IE chock the tires and have the brakes applied firmly.
Feb 08, 2018 | 2005 Chevy Silverado - 1500, Z71 - Euro...
Steps involve in precipitation
first losen cab mounting bolts then install your step tighten cab bolt after you have everything in line
Aug 02, 2013 | Stainless Steel Side Steps 4 in. Oval...
Canon A75 Broken Prongs in Memory Card Resevoir
Yes, memory card pin set are available for replacement. Unfortunately, camera needs to be disassembled to some point to replace it. The average cost may run around $75- $125 in US repair shops.
Mar 16, 2007 | Canon PowerShot A75 Digital Camera
Toys Logo
180 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
