Question about Mongoose 2008 Teocali Comp Mountain Bike
How to bleed brakes
Can not bleed brakes
    Master:
  • 388 Answers
You'll need a bleed kit and the appropriate brake fluid. Here's a video:
Posted on Apr 04, 2014
Can you bleed the brakes system from the top of the brake line
Can you bleed the brakes system from the top of the brake line Rick, No! I will post links to proper bleeding procedures, if you can not do it this way, take it in to a qualified shop. Some vehicles need to use a scan tool during the bleeding process to cycle the pump and valves.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Bleed Your Brakes Feature
Bleeding Brakes
How to do Complete Brake Flush and Bleed
Mar 22, 2016 | Cars & Trucks
How to bleed brakes
Bleeding brakes is pretty much the same across all vehicles. However, are you sure that there's air in the system and not a faulty brake master cylinder? The brake master cylinder has rubberised 'O' seals inside which, if worn, can cause a spongy pedal that has to be pumped before the brakes feel hard.
To bleed the brakes you need a length of plastic tube to fit onto the brake bleed nipple on the brake calliper. You can buy a brake bleeding kit which incorporates a non-return valve. The valve allows brake fluid to be pumped through it but prevents air from being drawn back up the tube into the brake system.
You can use ordinary plastic tube, but one end should be placed in a container of brake fluid to prevent air being drawn back in.
1. Locate the bleed nipple. Usually you start at the wheel nearest to the brake master cylinder (and then bleed each wheel in turn working your way to the furthest wheel from the car -if necessary).
2. Before you begin:Put a ring spanner onto the bleed nipple. Put a finger over the end of the bleed nipple to prevent air from entering via the nipple and 'rock' the spanner to make sure that the nipple will actually loosen. It is quite common for brake bleed nipples to seize then shear when turned with a spanner(wrench..). Don't use an open-ended spanner (wrench) otherwise the chances are you will 'round off' the bleed nipple.
3. Put the ring spanner on the bleed nipple and fit the bleed tube.
Get somebody to turn on the engine and slowly - slowly - depress the brake pedal. Undo the nipple slightly and brake fluid (maybe with air bubbles in it) should be visible in the tube.
get your helper to pump the brake pedal 3-4 times and keep the pedal depressed. Tighten the brake nipple.
4. Then repeat for each calliper if necessary.
5. Many cars have a split circuit brake system. That is, the front offside wheel is on the same system as the rear nearside wheel. The front nearside wheel is on the same line as the rear offside.
Here, you would bleed the front brake first and then the diagonally opposite rear wheel.
Plastic tube with non return valve for bleeding brake
Generic image - bleed nipple on calliper.
A bleed nipple. The open end is where the tube fits. Usually, you only need undo a bleed nipple approximately one turn. Use a ring spanner, not an open ended spanner.
Below: Bleed nipple can be seen on bottom right of calliper (generic image)
Below: Ring spanner on bleed nipple with tube attached.
Jan 21, 2016 | Cars & Trucks
Why does my brake pedel go down after I replaced my master cylinder?
Did you properly refill the brake system? Did you bleed it to get rid of air?
Jul 24, 2015 | 2004 Mitsubishi Endeavor
I have a ford escort xr3i 1988 i have replaced the brake master cylinder, bleed the brakes but still have no brakes what could be wrong?
Your car has a diagonally split brake system. Each side of this system must be bled as an individual system, and there is a correct bleeding sequence to be followed. First bleed the right rear brake, second, bleed the left front brake, then follow with the left rear brake and lastly, bleed the right front brake.Here's a link on a repair guide for bleeding your brakes. Repair Guides Brake Operating System Bleeding The Brake System AutoZone com
May 24, 2015 | Ford Escort Cars & Trucks
What are the proper steps to bleeding your brakes on a 1990 vw golf deisel
For left hand drive vehicles: (If the car does not have ABS system you do not need any diagnostic equipment!)
IMPORTANT NOTE: You need using diagnostic equipment connected to the data link connector of the car in order to bleed the ABS block. Follow instructions by scantool equipment for bleeding the ABS block.
1. This bleeding procedure requires two people. Remove the brake system reservoir cap, and fill up with new brake fluid until "MAX" level is reached.
2. Lift the car, or use a channel for access under vehicle.
3. Put the gearbox in "N" - Neutral position, or in "P" - Parking position for automatic transmission.
4. Start the engine and push the brake pedal firmly for 4 - 5 times to the floor, and maintain the brake pedal pushed to the floor.
5. Begin with the rear right wheel. Another person remove the dust cap and loose the brake caliper bleeding screw until the brake pedal goes to the floor. At this moment maintain the brake pedal pushed to the floor, engine idling, and tight the brake caliper bleeding screw. Use a plastic hose: one end connected to the brake caliper bleeding screw, and another end inside a recovery bottle for used brake fluid.
6. Repeat steps no.#4 and no.#5 until no air flows through the brake caliper bleeding screw. Tight the brake caliper bleeding screw, and put the dust cap in their place.
IMPORTANT NOTE: All the time check the brake fluid level in the brake system reservoir, and fill up if necessary!
7. Push the brake pedal firmly for 4 - 5 times to the floor, and maintain the brake pedal pushed to the floor, engine idling.
8. Continue with the rear left wheel. Another person remove the dust cap and loose the brake caliper bleeding screw until the brake pedal goes to the floor. At this moment maintain the brake pedal pushed to the floor, engine idling, and tight the brake caliper bleeding screw. Use a plastic hose: one end connected to the brake caliper bleeding screw, and another end inside a recovery bottle for used brake fluid.
9. Repeat steps no.#7 and no.#8 until no air flows through the brake caliper bleeding screw. Tight the brake caliper bleeding screw, and put the dust cap in their place.
10. Push the brake pedal firmly for 4 - 5 times to the floor, and maintain the brake pedal pushed to the floor, engine idling.
11. Continue with the front right wheel. Another person remove the dust cap and loose the brake caliper bleeding screw until the brake pedal goes to the floor. At this moment maintain the brake pedal pushed to the floor, engine idling, and tight the brake caliper bleeding screw. Use a plastic hose: one end connected to the brake caliper bleeding screw, and another end inside a recovery bottle for used brake fluid.
12. Repeat steps no.#10 and no.#11 until no air flows through the brake caliper bleeding screw. Tight the brake caliper bleeding screw, and put the dust cap in their place.
13. Push the brake pedal firmly for 4 - 5 times to the floor, and maintain the brake pedal pushed to the floor, engine idling.
14. Continue with the front left wheel. Another person remove the dust cap and loose the brake caliper bleeding screw until the brake pedal goes to the floor. At this moment maintain the brake pedal pushed to the floor, engine idling, and tight the brake caliper bleeding screw. Use a plastic hose: one end connected to the brake caliper bleeding screw, and another end inside a recovery bottle for used brake fluid.
15. Repeat steps no.#13 and no.#14 until no air flows through the brake caliper bleeding screw. Tight the brake caliper bleeding screw, and put the dust cap in their place.
16. Now the brakes are bleeded. Check the brake fluid level in the reservoir. Fill up with new brake fluid until "MAX" level is reached. Put back the brake reservoir cap.
17. Test the car brake system. The brake pedal movement no more than 1/3 of total stroke until the floor, when brake pedal is applied. Maximum admissible is 1/2 of total stroke.
Dec 06, 2010 | Volkswagen Golf Cars & Trucks
Replaced brake line, rotors and pads bled brakes all around and the brakes when the truck is off work but once i start the truck the brake pedal goes to the floor and have no brakes at...
Bench Bleed the M/C first, then do not let it run dry during system bleeding. Parts stores sell a kit that helps installed m/c bleeding.
Sep 29, 2010 | 2001 GMC Jimmy
Need sequence to blrrd brakes 02 dakota
Dakota, 2001-2005
Bleeding the Brake System
Brake fluid tends to darken over time. This does not necessarily indicate contamination. Examine fluid closely for foreign matter.
The primary and secondary hydraulic brake systems are separate and are bled independently. During the bleeding operation, do not allow the reservoir to run dry. Keep the master cylinder reservoir filled with brake fluid. Never use brake fluid that has been drained from the hydraulic system, no matter how clean it seems.
  1. Clean all dirt from around the master cylinder fill cap, remove the cap and fill the master cylinder with brake fluid until the level is within 1 / 4 in. (6mm) of the top edge of the reservoir.
  2. Clean the bleeder screws at all 4 wheels. The bleeder screws are located on the back of the brake backing plate (drum brakes) and on the top of the brake calipers (disc brakes).
  3. Bleeder screws should be protected with rubber caps. If they are missing, the orifice may easily become clogged with road dirt. If the screw refuses to bleed when loosened, remove it and blow clear. Aftermarket caps are readily available.
Bleeding the ABS System
This is accomplished using the same methods as for the base brake system. Refer to those procedures.
ABS system bleeding requires conventional bleeding methods plus use of the DRB scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
  1. Perform base brake bleeding. Refer to the appropriate section.
  2. Connect the scan tool to the data link connector beneath the dashboard.
  3. Select "Antilock Brakes" followed by "Miscellaneous", then "Bleed Brakes". Follow the instructions displayed until the unit displays "Test Complete", then disconnect the scan tool and proceed.
  4. Perform a base brake bleeding a second time.
  5. Top up the master cylinder.
Hope helps (remember rated and comment this).
Aug 26, 2010 | 2002 Dodge Dakota Club Cab
Bleeding brakes 2000 suburban wsith ab
Why were the brake lines replaced?
Sounds like the mastercylinder may have run dry. You have to bench bleed the master and then DO NOT allow fluid to run low, while bleeding brakes...
if master cylinder runs low on fluid and air gets in, almost impossible to bleed with out releasing the lines and bleed master it self.
Sep 20, 2009 | 2000 Chevrolet Suburban
Brakes
First bleed the MC, Remove the brake hose - block the outlet of the MC with your finger - pump the lever and crack you finger loose for an instant to bleed the air out - repeat til only fluid comes out. Quickly install the brake hose. Bleed the brakes by cracking loose the brake hose bolt. Bleed at the caliper bolt. Bleed as normal with the bleeder valve.
Nov 10, 2008 | 2002 Yamaha WR 426 F
Mongoose 2008  Teocali Comp Mountain Bike Logo
81 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
