Question about Brother DCP Office Equipment & Supplies
Fault finding ink is full but red colour is not printing
    Novelist:
    Scholar:
  • Brother Expert
  • 181 Answers
Magenta Print-head may be blocked.
Depending on the model of machine.
Either on the Menu on the printer find Ink Management or press the Ink Management button.
Print a Test Page
If no Magenta Dots showing then proceed to Cleaning and Clean the print-heads through the proceedures given on the machine.
Print another test page. If Magenta Dots are fine then cleaning done. if not then try cleaning again.
If still not fine then the machine will need to be cleaned professionally which will cost a reasonable amount. Most service fees are more that it is to replace the printer.
Posted on Nov 25, 2014
SOURCE: printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Posted on Jan 05, 2007
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
  • 116 Answers
SOURCE: Black ink not printing
replace print head assembly
Posted on Aug 02, 2009
n25an
  • 622 Answers
SOURCE: want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
Posted on Dec 21, 2009
cns assoc
  • 677 Answers
SOURCE: Do all ink cartridges need to be full to print? I
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 14, 2010
My printer is printing blank pages do I need to change any settings it did print one in colour but no more
are you sure the inks are full ? it will only print out whatever ink it has left ? if inks are ok go to/control panel on laptop/click open printers/find the name of your printer/ now RIGHT click on that name and go down to "properties" look along the top of that tab and see "maintenance" you will find the settings in there for paper size/colour/head clean etc
Apr 29, 2015 | Canon MG5250 Printer
Tip
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master technician on your particular product and have ready access to print heads and machine engine unit replacements, you will also need manufactures service software/website to reset waste counters/error codes.
It is expensive to print in colour full stop. Printing cost is at least 30cents ink-jet and 10cents toner/laser per sheet
Laser b/w and colour is far cheaper per sheet, but setup costs are one time expensive but they are also a lot more reliable printing system.
Your machine will stuff up sooner rather than later when using non genuine consumable, and when it does it will cost more than the machines worth to even look for repair, so be prepared if choosing this road to purchasing a new printer every few cartridges if you are lucky.
If your using non genuine products and you want machine looked at by a professional the first thing you will need to do is install all genuine products in to your machine to allow correct fault diagnostics to be done, this is before any repair cost that maybe incurred.
Recycled/refills/aftermarket ink cartridge faults include – not recognizing ink, poor print quality, error codes, wont come to ready, erratic carriage movement, lines, waste counter issues and also paper feed problems, circuit board/connection faults caused by leaked ink
All machine manufactures have websites where you can download drivers and software needed for operation with your computer
Listed below are the main sites, if you’re having trouble finding any then remember Google is your friend.
Cheap printing can be achieved using b/w lasers they cost less than 2 cent per sheet and have a brilliant reputation for print quality and dependability. Then if you need the occasional colour go to the shop, let them have the hassle, stress, time and expense of running the machines and the cost is still relatively cheap to you.
There are many consumers still printing with 10 year old laser machines, you would be extremely lucky to find a 3-5 year old inkjet. I did find one inkjet customer that impressed me. He runs a cake shop and he prints with a Epson inkjet that uses edible ink printed on paper like icing sheets to decorate his cakes.
If you must recycle well buy one that has already been proven to be adaptable to the concept, so that means go back to older units that were not so clever.
Older Lexmark, Epson and HP were once easy targets, there was and is a lot of development gone into managing bulk ink delivery systems,and software has been cracked and parts can be sourced
Most new machines come with starter inks that do not contain as much as new ones usually 3ml instead of 5ml to enable cheaper selling cost, but also note that about 2ml of ink is in the tubes that run from ink carts to print head. These modern machines have all sorts of tricks and chips inbuilt that will discourage any refilling attempts
People that need to do colour printing like more than 8 pages a day, should be using full colour toner based print systems.
ie OKI, HP, Brother, and Kyocera all have great reliable printing systems, The OKI c9600/9800 series is a brilliant photo quality aka What you see on display is what you get on the paper full colour laser printer
Happy Printing
Soulvisitor.
Brother Epson Sharp Canon Lexmark OKI Dell HP Kyocera Samsung
on Dec 22, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Why is my printer not printing right
This sounds like the chip on the ink cartrige, try cleaning the chip or replacing the red magenta ink. How a printer works, information from the Dynamic Link Libary is sent to the printer driver, this information is where to print on the paper and what colour to print, ie turning the ink jets on and off, the depth of colour comes from each ink by mixing the inks from the information in the photo or text. All ink problems are usually from ink faults, miss printing comes from driver information. Phill
Jan 15, 2013 | HP PhotoSmart Office Equipment & Supplies
Photos colour is red
Use the software on the CD that came with printer, to run a "head-cleaning" cycle -- the ink is not getting from the ink-cartridges, through the ink-jets, onto the paper.
Apr 23, 2010 | Epson Stylus Photo R300 InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
Colour printing very "off"
is that when you print , or when you scan or make photocopies
Mar 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Red colour prints brown
Just replace the non genuine inks with proper Canon ones and then do about 4 full cleans, that should fix it. If not you will have to replace the printhead, which is usually caused by using non genuine ink. Good luck
May 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Red ink not printing
the channels for the ink to flow are really minute [small] if ink dries up in them it can take some time to soften it up before anything will flow. try deep cleaning the printhead.
Jan 07, 2007 | Brother DCP-110C All-In-One InkJet Printer
Low black ink - can not print at all
Most epson inkjets that use separate colour and black cartridges will not print if either the colour or the black cartridge is empty. The printers come with cartridges when new but they are only part full and more ink is used up filling the printer reservoir when first starting up. Replace your black cartridge and you should be able to print. barrie60s
Jul 24, 2006 | Epson Stylus C88 InkJet Photo Printer
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
