Question about Motorola T8500 Two Way Radio
Immediately off the charger the unit shuts itself off as soon as
We have 42 radios tha t staff use to communicate and one of them tuurns itself off right after it comes off the charging cradle. it is frustrating and would like to know if there is a setting we are unaware of or what.
  • Motorola Master
  • 1,654 Answers
You did not mention the age of your rechargeable batteries. If the batteries are more than 18-24 months old, you may need new batteries. An easy test would be to switch a known good battery into the radio with the problem. If it solves the problem, replace the battery.
Posted on Jun 15, 2009
My Walkie Talkie from Cobra, Model ACXT645 keeps turning off by itself.
Battery save mode takes over quickly. As the battery runs down, the radio will shut itself off. It is not something you can unprogram. If you leave it on the charger and expect it to stay on, I can only speak from experience of another brand I use as an in house intercom. The charger tops off the battery and somehow shuts charging off, allowing the radio to run dead in the charger! I'm a tech and cannot figure a way around this, it sucks! This this what you meant? Here is the manual link: https://www.cobra.com/sites/default/files/manuals/CXT645_MANL.pdf Let us know! Jay
Mar 20, 2018 | Radio Communications
Visual Land 10in Tablet will not turn on after charging
If the tablet works while plugged-in to the charger, yet dies immediately when the charger is disconnected, it means that the rechargeable battery in the tablet is dead.
If the unit will not turn on at all, even with the charger attached, the charger itself may have failed, or the unit may be having other issues.
May 15, 2015 | Tablets & eReaders
Telecom r100 battery
It could be one of these three things.
1. Bad port. Often in laptops these ports become loose.
2. Bad battery.
3. Bad charger.
Borrowing either a universal power charger, or the charger from someone with a similar laptop, can eliminate some of the possibilities unless it is indeed your charging port.
If after plugging it in, the battery charges you know you had a bad charger. If the battery fails to charge, you know its time for a new battery. Again this only if the port itself is not bad.
Universal chargers can be expensive. You can find batteries and chargers on Ebay for a decent price.
Mar 01, 2014 | Dell Computers & Internet
Ptt cant go through
It is possible you have a battery or charging problem. Transmitting takes more energy than any other function of the radio. Pressing the PTT can quickly reveal a bad or poorly charged battery pack. Check your charger, clean all battery contacts on the charger and radio with a pencil eraser and try charging again. Also, you can try changing a battery out of a known good unit and see if the problem moves with the battery.
Jul 28, 2017 | Motorola SX600R Two Way Radio
My motorola sx800 goes on but when you push the talk button to communicate it always goes the same way like how you turn it on first. so i hope i can get some answers for my motorola walkie talkie.
It sounds like a bad, defective, or low battery. It takes more energy to transmit than to receive, or to be idle on standby. Pressing the PTT button to transmit with a low or bad battery would cause the radio to shut down or nearly shut down.
Try another battery pack in your radio or swap batteries with a known good unit to confirm the battery is the problem.
Other problems might include the battery being poorly charged. Check your charger. Or you could have an overall problem with the radio itself. This is a non-repairable unit, so if it is the radio you would need to retire it.
Clean all your battery contacts with a pencil eraser to make certain of a good connection.
Best regards.
Sep 09, 2011 | Motorola SX800R (22 Channels) 2-Way Radio
I have a two way motorola sx800r. I bought 5 sets of the radios. I can hear from any radio. But only one radio will transmit to the rest of them. It has to be a setting. I just don't know which one. All...
We could not immediately find a manual for the SX800, but here is a link to the SX700 which is very similar. http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
With the radio unlocked: You should check your Qt filter to see that it is also programmed the same. It is recommended you use it in the off or minus position for best communications. If this does not solve the problem, try setting all the radios back to the basic Channel 1, Code off, Qt off, position and see if they will work together. Shut off any special features such as vibra call and call alert, as these when not used correctly can also cause issues with inexperienced users.
If this does not solve the problem. Lastly, check your chargers and batteries. Clean battery contacts with a pencil eraser. Trade batteries from the known good unit into one of the others to see if it solves the problem.
Aug 15, 2009 | Radio Communications
Garmin 260 now failing to charge and shuts itself down
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Jul 24, 2009 | Garmin nuvi 205 GPS Receiver
Blinking red power buttom
Hi frog31
I would suggest you take the unit back to the repairer immediately , they MUST fix the problem for you on their cost.
May 04, 2008 | Radio Shack Cinego D-1000 Multimedia...
Blinking and Whining
I had this happen, and I solved it by connecting it to the car charger for a while, then bringing it in and connecting it DIRECTLY to the AC charger for a full charge. (This assumes the battery is not just kaput.)
Here's what I think happens: The AC charger doesn't have enough current capability to run the unit by itself AND keepp the battery charged (bad design), so, if left continuously ON, the battery will eventually drain. In this state, if you shut it off, the unit senses a low-battery condition and will try to charge, but the charging circuit tries to draw too much from the AC charger and the voltage droops (causing the whine) to the cutoff point (causing it to stop charging, another case of bad design). The car charger has more current capability, so it gets the battery charged enough to use the AC charger again.
Nov 28, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Motorola T8500  Two Way Radio Logo
85 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
