Question about Internet Q See Ufo CCD Camera
When trying to connect to my Q-see system via internet I get DVROcxEx.cab ... Connect fail! Have any clue what I should do to fix the issue... I have ActiveX set to enable on everything and I have Security Allow options checked... and I have turned off my firewall's... when I view Add-on's it shows DVROcxEX is enabled...
  • wbefield May 11, 2010
    I have this same problem.. have you had any luck?
  • 4 Answers
I had same problem, this fixed it. internet explorer. tools>internet options>security>custom level> Under active X controlls and plugins, make sur they are all enabled or prompt. there are like 4 of e u have to change.
Posted on Dec 15, 2009
Simple solution choose for the plugins to prompt or enable for active X
but also add the dvr website address to trusted sites in IE
Posted on Oct 15, 2010
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Adding to trusted sites is a good suggestion. Also make sure you are in fact using Internet Explorer. Many browsers are not compatible with anything else. Q-See can be tricky and they are manufactured by many different companies depending when you purchased.
Posted on Feb 14, 2015
Can't download anything on my Acer Aspire 5552-3691
I don't see a question above, so I'll just assume that you're asking how to fix your computer so that you can connect to the internet. Is that correct?
If so and since you have reset your computer back to factory settings, you should check that all of your software is updated to the latest versions. This would include your operating system and drivers.
Then, you should check that your computer can connect to the internet via ethernet (RJ-45) cable. You would want to directly connect your laptop using the ethernet cable to your router. If this works, you can move on to trying to connect via Wi-Fi. If this doesn't work, you should check that there are no software/driver issues and/or hardware issues with your computer.
If you are trying to connect via Wi-Fi, again you will want to check that all drivers and software are up to date (so that you are on the latest versions of your operating system and the Wi-Fi care inside your computer has the latest driver so that it can connect to your wireless router). Then you will want to attempt to connect and most likely re-input your Wi-Fi password.
Dec 30, 2013 | Acer Aspire 5552-3691-24271 Laptop
Can't connect to wireless,but can connect via cable
As you have mentioned that you can connect to internet via cable but not wirelesslly without cable.
Well my brother the wireless issue can be fixed just even with in few minutes but sometime it takes lot to fix. here few things are missing that which window are you using and when was the last time it was working.
Try to follow these steps one by one i am sure it should work:-
1.Check your wireless switch and make sure it is ON.
2.check your wireless connection status and make sure its connected.
3.Perform a system restore>>how to open system restore
start>>all programs>>accessories>>system tools>>system restore>>left click on system restore>>click next>>it shows a calender and here you can choose the date when it was working>>so select date and hit next>>hit next next and will start the system restore automatically>>computer will restart automatically and then check your internet without cable
If still wireless does not work then try to call your Internet Service Provider.
Mar 06, 2011 | Acer Computers & Internet
It won't connect with laptop
Here are a few simple things to check:
If your PC is connected via wireless:
- Make sure you didn't go out of signal range
If your PC is connected via wired cable:
- Make sure the cable is secured into your router
If both check out:
- Check the cable between your router and internet modem.
If all connections are solid:
- Try using a different cable from the PC to the router, and from the router to your internet modem. Cables can go bad, and a new one could be an easy fix.
If all else fails, you may have experienced an intermitted connection issue:
- Try unplugging your internet modem and router for 30 seconds, then plug in your internet modem first and after 60 seconds plug in your router.
- Try restarting your PC
If none of those work, contact your Internet Service Provider.
Jul 12, 2010 | D-Link DIR-615 Router
2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I get error message DVROcxEx Connect Fail! ... how to avoid this?
My computer does not accept DVROcxEx.cab. What do I have to do in order to download and instal it
Jun 24, 2009 | Internet Q See Ufo CCD Camera
Init. Fail
I have the same problem with mine it keeps popping up "Init fail !" when I try to connect.
But I've found another way you can connect:
goto START, type RUN then "ncpa.cpl" and enter, then left click your mouse and connect to tmobile internet.
This is how mine got working.
Jun 20, 2009 | Computers & Internet
I get Connect Fail in DVROcxEx.cab
This application uses port 2000 to work, as far as you are using Cisco products in your LAN and NAT to reach internet, port 2000 is used for Cisco products (SCCP), you need to change the cameras port
Jun 15, 2009 | Internet Q See Ufo CCD Camera
Playstation 3 online problems
Firstly if you connect to the PSN via wireless router, the router maynot be able to cope with the BIT rate that is needed to play the game.
My suggestion is:
- That you are hard wired to the internet - i.e connected via a modem cable.
- Go to your ps3 system menu and check the internet connection.
(the PS3 will now check IP address etc and say that is enabled)
- If this is the case (which it should as you can connect to the internet browser)
- This time disconnect the modem cable and turn off the PS3 (in that order).
- Turn on the PS3.
- Carry out system check it will be unable to give a success as your not connected.
- Once complete reconnect cable and ensure that wired connection is selected.
- Carry out check again.....success should be shown.
(the reason you do this is to get both PS3 and server to communicate as if they have never met before so it sets up a new partnership)
- Insert Disc and Enjoy
- I hope this has helped????
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Can't connect to internet via wireless
First, try uninstalling the wireless drivers from the device manager, then reboot. The machine will find the wireless and reinstall the drivers automatically. If this is a driver glitch, this will clear it. If it still doesn't work, then take the laptop somewhere that has free wifi, if you can connect through their service, then the problem is with your internet provider. If you still cannot connect, then it may be a failed wireless card, or a dirty or corroded card slot or antennae lead. Try these, get back to me with the results, and we'll go from there.
Aug 12, 2008 | Dell Inspiron E1505 Notebook
Http error $code$
i've gotten that a couple times when trying to connect via the internal modem, a simple reset usually fixed it. If your wifi settings are messed up make sure your wifi switch is on, ensure it is enabled in com manager too. Also, try removing the wireless network via the software and adding it again. if all that fails do a hard reset. If that fails you are pretty much out of luck. I had two MDA's.... they both slowly got **** as months went by and i constantly had to reload the firmware, you may want to consider a different model
Jun 11, 2008 | T-Mobile MDA
Internet Q See Ufo CCD Camera Logo
15,466 people viewed this question
Top Internet Home Security Experts
Lawrence Oravetz
richie46
U-Spy Store DBA Pro...
Level 1 Expert
Are you an Internet Home Security Expert? Answer questions, earn points and help others
