Blinking power light
I am watching a movie on my PC, when all of a sudden the screen goes dark, the power light on the PC goes out, but the hard drive light is blinking. What is causing this?
  • 1,249 Answers
Computer went to sleep on you. Set movie watcher app to stay awake while playing video.
Posted on Mar 31, 2014
  • 74 Answers
SOURCE: PC powers up but the screen does not come on
your pc is infected of viruses.try to reformat your pc
Posted on Jan 31, 2010
  • 146 Answers
SOURCE: Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Posted on Jan 14, 2008
SOURCE: Computer locks up suddenly & screen goes blank
I have the same problem, the hard drive light stays on and the system freezes. I tried making sure the CPU was cool enough but it didn't seem to help. Also, I noticed that the CPU fan appeared to be running and when it froze then it shut off. Any help would be much appreciated, Thanks!
Posted on Apr 27, 2007
  • 78 Answers
SOURCE: I was using my netbook
check BIOS if it detects a hard drive. if not, try to manually detect it. if it fails, it is a hard drive problem
if it was able to detect a hard drive. you should be able to do a system restore. Read the manual that came with your netbook for full instructions and illustrations on how to do a system restore.
Posted on Nov 08, 2010
archaeology
  • 662 Answers
SOURCE: My desktop suddenly suspended, switched it off by
You are the owner of a desktop PC that has developed a sudden and catastrophic hardware
fault - probably on the motherboard (since even the ROM BIOS doesn't give evidence of its
existence), but possibly in the power supply.
Desktop PC power supplies are (relatively) easily replaceable, so if you have as many spare
power supplies lying around as I do, try replacing that first - if that doesn't fix the system, then
the problem is on the motherboard.
Since your power supply is alive enough to light the power LEDs on the system unit tower and
also the keyboard, the problem is probably on the motherboard - look at it - there may be an obviously burned visible component - but there usually is no visible sign of the fatal failure.
The reason I do not suspect your HDD (hard disk drive) has crashed is that ROM BIOS
executes at (power start) boot time right out of motherboard-mounted ROM, independent of
whether or not the HDD is functional - and since not even the BIOS message appears on your monitor, I therefore know that the boot sequence has been interrupted long before the computer becomes intelligent enough to find and access a disk drive, and then command it to try to find a
boot sector.
How to fix the computer: isolate the boot problem to the motherboard. Replace motherboard.
Posted on Sep 05, 2011
Hp probook wont boot
please select boot device from bios
Sep 16, 2013 | Computers & Internet
How do i adjust my backlight timer?
Open Power settings, in the Tray Notification Area or Control Panel, Power options, change to High Performance, Advanced Power Settings, Adjust Dim display. If it is on battery it will dim display to save battery.
Dec 22, 2012 | Computers & Internet
Hi, when I turn on the Acer Aspire 5920, the acer screen comes on, the bar across the bottom moves, then it goes to a blank dark screen with a blinking cursor. I have tried turning off and turning on and...
Check if your hard rive indicator light is flashing (has disc shape icon or can shape icon next to it). If it is then put in your windows disc and do a startup repair. Make sure it is booting from the disc drive first. if it isnt flashing then you may have a dead hard drive. Try taking the hard drive out and putting it back in.
Mar 19, 2011 | Acer Aspire 5920-6727 Notebook
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
10 blinking light.
It is called mainboard and is the one where you plug your video (HDMI,component) cables if you want to order a new one you need your product code, it is located in the back of the TV, same place as the serial number.
May 27, 2009 | Panasonic TH-42PZ77U TV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Wd external stopped working
The round lights on the front of the drive are actually power off/on button. Have you tried pressing it? I know it's simple, but you never know. :)
Feb 18, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
