Dude, changing paper orientation on paper tray is just one step, while you must change paper setting on printer driver too. In some machines, you should change paper switch position too :)
Open and close the paper tray 3.The tray information screen will be displayed.Select CHANGE SETTING on the touch screen.You should now be able to change your setting.
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
if you want change page setting in your printer ..... to get
the all settings of your printer press font button and switch on the
printer (before take setting make sure that you printer loaded with
paper ) goes through the instruction printed in the paper to change the
settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
you need to change the paper size on the copier or the paper tray dial.you can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Change your Paper type in the Paper Handling Menu. Is paper fed from tray 2 or tray 1? Either setting, the paper type can be changed using the control panel. Press the green button to enter the menus, then using the "down" arrow button, press until you notice the "Paper Handling Menu". You can change the setting from Rough Paper to Plain. I hope this helps.
Issue
When using colored paper in the all-in-one, printing or copying is slow.
Solution
This
issue is a result of the automatic paper type sensor misreading the
colored paper as photo paper. The print out takes longer because the
unit is printing in Best mode instead of Normal mode.
Follow
the steps below to temporarily change the Automatic Paper Type setting
from within the application that you are printing from.
Click
File
, then
Print
or
Print Setup
Select the appropriate all-in-one from the drop-down list and click
Properties
Click the
Paper/Quality
tab and under
Type is:
select
Plain Paper
Changes
made within the application might not be permanent and the setting will
default back to Automatic after closing the application. The setting
will have to be changed each time colored paper is used in the
all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE:
By
following the steps below, the default Automatic Paper Type setting
will be changed to Plain Paper. In order to use a different paper type
in the all-in-one (e.g., photo paper), the setting will have to be
temporarily changed to reflect the new paper type.
Click
Start
, point to
Settings
, and then click
Control Panel
Double-click
Printers and Faxes
Right-click the appropriate all-in-one, and then click
Printing Preferences
Click the
Paper/Quality
tab and under
Type is:
select
Plain Paper
This sets the default paper type setting to Plain Paper.
