Question about Meizu M6 miniPlayer
How open it to replace battery
I want to open it and I don't like to destroid it
Hi, was woundering what type of battery the invita pro diver 12860 watch takes,thaks
You probably don't need a special tool to open your watch. Many jewelers offer battery replacement at reasonable cost.
Jul 16, 2016 | Watches
Why doesn't trunk open with remote
If you have never replaced the remote's battery, it may be time. The 'coin' type batteries do live long but not forever and mfr.s typically suggest that the lithium cells have a 'shelf life' (unused) of more than five years.
I don't know the construction of your remote so don't know if the battery is user-replaceable or not and if not, the dealers usually take advantage of customers when they can. The batteries alone are cheap costing a few dollars at worst.
If you have the 2nd remote stashed somewhere, you might try it if it has not been in use. Even then, the battery may quickly be depleted in the spare too.
May 27, 2012 | 1999 Buick Century
Battery needs to be replaced, my understanding is the replacement needs to be done by a professional, due to calibration issues. Please advise LeiLani Salinas
hi
I don't think is there is any calibration issue while replacing the battery. For replacing the battery you have to open the ECG machine. its a 12v 1.2Ah battery. It will hve to plugs remove the two plugs and remove the old battery. install the new one in position and reconnect the plugs. only thing you have to remember is do not interchange the positive and negative terminal.
ok
Aug 11, 2011 | Schiller Cardiovit At 1 Ecg Machine
How to replace battery in dell inspiron 8000
I assume you mean the CMOS battery? The battery is located on the motherboard, in a little cradle. Unplug the computer, open the side. Be careful to earth yourself so that you don;t transmit a charge to the motherboard. Carefully remove the old battery (I use a small flat bladed screwdriver) Insert the new one, replace the cover, re-connect the mains and turn on!
Jul 20, 2010 | Dell Computers & Internet
I have two lcd tv with the screen broken and another with the electronic destroid . all the 3 are 32 inc lcd but made by different producers. Can i substitute the broken screen with one of those with...
You will not be able to mix match parts to make one TV even though they are all 32 inches. Technology and applied differences are vastly different between all the TV manufactures.
You could try to sell your 3 broken TVs for parts and then put that money towards the purchase of a new TV.
Good luck.
May 24, 2010 | Televison & Video
A/c compressor 4 time destroid
Likely there is debris in the system that needs to be cleared. Many systems have a filter screen that becomes plugged up and needs to be changed. (filter, orfice tube or whatever ) also make sure reciever dryer is replaced as well.
Apr 19, 2009 | 1995 Toyota Camry
I RESTARTED MY LAPTOP NORMALLY BUT IT WONT TURN ON
Hi
Try starting it up on safe mode, and then restore the pc to later date.
Let me know what happens
Mar 27, 2009 | Dell XPS M1530 Notebook
My notebook S96F bios donĀ“t recognize my keyboard
remove the battery and power cord then open the system find the battery on the motherboard remove it carefully let it set out for 10 min. then put the battery back on the motherboard put the system back together replace battery and power cord cmos should be reset
Nov 26, 2008 | ASUS M5N Combo Notebook
Monitor will not function properly
well that sucks.. i suggest you should acquire a boot disk.. you can create by yourself using another person's computer like your friends or office colleague.. then you can boot up on your pc and reinstall your operating system...
Jan 23, 2008 | Computers & Internet
Meizu M6 miniPlayer Logo
50 people viewed this question
Top Meizu Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Meizu Audio Player and Recorder Expert? Answer questions, earn points and help others
