Question about CookTek MC1800 MagnaWave Single Induction Cooktop
Internal fuses keep blowing out on the CookTek MC1800 Magnawave Single Induction Cooktop
Internal fuse keep blowing out
I have whirlpool induction cooktop and it does nothing. I have current and nothing. I was wondering if the fuse could be bad. The fuse is 30A/250 an couldn't find one so I tried 20A/50 not
You will definitely need the correct fuse. Get someone competent with a meter to test the circuits. Test the original fuse before going further to see if it is OK or not.
Nov 15, 2014 | Whirlpool GCI3061XB 30" Induction Cooktop...
Cooktek error code e 4
Hi, the electronic board is overheating, make sure that the cooling fan beneath the unit is working and the screen or airflow is not obstructed.
Feb 16, 2014 | CookTek MC3502F MagnaWave Double Induction...
Electrolux induction hob stripdown
there should be screws at the back loosen then push forward and that should do it x
Sep 25, 2012 | CookTek Magnawave 3500W Single Hob...
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
Cooktop short circuits the electrical fuse when plugged in
Try removing parts or connections until the fuse does not blow.
With a gas hob, you are limited to a short in the ignition system.
As the igniter has failed try removing it. This should solve the fuse problem, if it doesn't, look for a short in the wiring.
Jan 09, 2012 | Thermador 46 in. SGSX456 Gas Cooktop
My Kitchen Aid Model KECC507 electric cooktop blows a fuse when I use all four burners. I am using 4x20amp fuses.
The fuses should be at least 35 amps the ones you are using are rated to low for the range.
Oct 10, 2011 | Cooktops
KitchenAid Electric Cooktop Model KECC507 -- when I use all four burners it blows a fuse. There are 40x20amp fuses
sounds as if your fuses are rated to low for the range they should be at least 35 amp fuses
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
CookTek MC1800 MagnaWave Single Induction Cooktop Logo
143 people viewed this question
Top CookTek Cooktops Experts
Paul Carew
Are you a CookTek Cooktop Expert? Answer questions, earn points and help others
