Question about Canon IR1022IF 220-240 VOLT, 50/60HZ
Canon ir1022 printing blanks
Is printing blanks what can be done
Replaced a printer cartridge type 106 with same. Everything was done according instruction. The printer printed several pages and now will not print anything but a blank page. what needs to be done to...
Check to see that the toner cartridge does not still have a "Pull Strip" on the cartridge. or Remove the cartridge and gently rock the cartridge a few times in your hands and re-install.
Jun 25, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
The PGBK cartridge doesn't print anything
Do a selftest on the printer. If the Selftest prints out something, uninstall the printer Driver and reinstall it again. If it still did not work checkin the printer to a qualified technican to have a look at it.
May 12, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon MX850. Print blank after ink changes. The black ink, PGBK-5, ran out so I replaced it with a cheap generic ink tank. But it didn't work, nothing print, not even color copy. I thought the ink is bad...
That is a common problem on all Canon printers, the purge assembly on the right where the printhead parks, has a pump inside and hoses that go to the filters and ink absorbers. When that unit goes out you need a replacement. A job best done in a shop. When the printhead is not cleaned and primed properly you get blank pages no matter how full the inks are.
Dec 24, 2009 | Canon PIXMA MX850 Multifunction Printer
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Oct 04, 2009 | Canon MX300 Office All-In-One Printer
CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Mar 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How to clean cannon iR1022 printer to stop getting black streaks on pages
Hi
Try running a head cleaning cycle from the maintenance menu, then print a nozzle check. try to run 3 head cleaning cycles then try printing again
Nov 17, 2008 | Office Equipment & Supplies
Prints blank pages only
Try brand new genuine cartridges, if that does not work, it is your printer's print heads. Canon has these built into the printer as opposed to having them built into each new cartridge. Sometimes cleaning the heads a few times does not do much at all. On some occassions I have cleaned the print heads over 20 times and have succeeded eventually in getting it to print. Good luck.
Sep 06, 2007 | Canon BubbleJet i560 InkJet Printer
Canon IR1022IF 220-240 VOLT, 50/60HZ Logo
37 people viewed this question
old marine
old marine
