Rx v340rds yamaha
The volymkontrol ist no working ,the sound that I hear its distoratet, When I do test for speakers it comes sound from every speakers
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Check each individual cable for open at the back of the system
Posted on Apr 03, 2014
The Marv
  • 72 Answers
SOURCE: JVC RX-618V SOUND IS MUFFLED
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
Posted on Aug 05, 2006
SOURCE: yamaha stereo receiver rx-830
Does your TV have any audio outputs such as RCA perhaps?
Posted on Jan 13, 2008
  • 165 Answers
SOURCE: yamaha rv1000
ok yu problem has to be with the protection system before you burn it up it collapses to protect the whole system.....go direc to the thermal cut off devices on the main output and then to the power system......
Posted on Nov 17, 2008
easyq
  • 144 Answers
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Posted on Apr 17, 2009
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
were you able to solve this one ? I have the same problem with mine. The only way to clear the lack of sound in one of the speakers is to rotate the input knob !!
Posted on Dec 20, 2009
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
I have a Yamaha RX-V340RDS amplifier and need to know how to connect my tv, dvd recorder and hd-pvr
manual found here: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RXV340.pdf
Mar 23, 2014 | Pioneer VSX-D608 Receiver
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
Hi I have a yamaha rx-v863 there is no sound comming out of the 2 front speaker, heven if i put it on 2 chanel, what shoul I do? Thanks Beb
Crack the manual open and do the speaker tones test to verify the hardware. Come back with the results.
Aug 15, 2011 | Yamaha RX-V863 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Main speakers A and B not working...
Please preform Test Tone check and adjust front speaker level that seems very low.
Feb 20, 2009 | Yamaha RX-V2090 Receiver
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Center speaker still not working :(
all your speaker channels are working so your problem lies with a setup fault. when you watch tv you are only feeding a stereo signal into the amp. you need to select the internal surround sound generator. you need to select either the movie or surround function. the unit will convert the stereo signal to 5.1 channel surround.
May 26, 2008 | Yamaha RX-V595A Receiver
14 people viewed this question
 Grubhead
Grubhead
