Question about Sewing Machines
Timing affected I had a fabric jam and think that the timing is affected.The left needle is not looping. The other three threads are looping, but not stitching on the fabric.Can I adjust the timing myself or do I need to take my overlocker to Elna for repairs & Services?
  • Sewing Machines Master
  • 1,388 Answers
NOT a home fix unfortunately
Posted on Apr 22, 2014
My stitch wont stay in the fabric what am i doin wrong
needle thread tension worng
no thread in the bobbin
neeld /hook timing is wrong
May 14, 2017 | Sewing Machines
Top thread leaving loops on the bottom of the fabric.
what you describe is an indication of the needle top thread tension being too loose
make sure that the thread is between the pressure plates of the tensioner and not behind it
next remove the plates around the base at the bit the moves the material through so that you can see when the needle is approaching the bobbin hook
when the needle is at the bottom of the movement, that bobbin hook should be almost at the eye of the needle .
that is called needle position timing
if the hook is not near the eye of the needle or past it then you will have to have the machine serviced and that timing corrected
check the way the need is installed
the cut away bit should be facing the hook and the small groove is where the thread sits so that it does not jam as it goes through the material
Sep 24, 2015 | Sewing Machines
Top thread will not loop bobbin thread
Try re treading it. After you have guided the thread thru the eye of the needle turn the wheel until the needle goes all the way down. Keep turning and as the needle starts to come up pull on the needle thread and it should loop the bottom thread and pull until both come back to the top. Now you are ready to sew.
Mar 11, 2015 | Singer 2662
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Dec 08, 2014 | Sewing Machines
Singer 4423, timing out,what line up with what
I don't think it's a major timing issue, so don't panic. Take a look at your selected stitch pattern selector and set for straight stitch, and set Tension at 3-4. Width: 4. Length: 4. Make sure presser foot Down when you rethread machine so the tesion disks open up to locate thread. Always hold thread taut when "feeling" for tension slot. Insert new needle. Needle goes all the way up into needle clamp as far as it can possibly go, FLAT side needle toward needle bar and more rounded side needle facing you. Leave 6" tail. Hold thread toward you as you turn hand wheel toward you so needle can make a loop with bobbin thread. Make sure bobbin thread isn't hanging down on or across bobbin! Make sure thread in bobbin has wound evenly - good quality thread ideal! Clean bobbin area and feed dogs for broken, loose threads and lint. Always use needles appropriate size for weight of fabric. I suggest walking away from machine, taking deep, cleansing breadth, humming a favorite tune, then doing above and see how it goes! Soon your machine will be humming happily along with you. Hope these suggestions help. Jimmy
Mar 31, 2012 | Singer 4423 Sewing Machine
Thread is clumping underneath
Unfortunately, the machine's timing may have been adversely affected during the jam and removal of the fabric. Here's something that may resolve the issue if it is not timing-related:
Install a brand new needle.
Remove all the thread from the machine.
ALWAYS RAISE the presser foot when threading the top thread!
Rethread from the beginning and verify the thread path is correct.
If you have a smoothly-wound bobbin, try that. (A bobbin that you describe will contribute to sewing issues.)
Install and thread the bobbin--confirm the bobbin is spinning the right direction in the bobbin case.
Re-test your machine.
If you are having issues with the bobbin not winding smoothly, there are standalone bobbin winders for about $30 on the market (local JoAnn's or on the internet) called Sidewinder. Confirm that your machine bobbins will work (there are a few machines that won't, I think Singer). This is a very good accessory to have since you can wind bobbins without having to unthread the machine and also saves wear & tear on your machine.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Mar 24, 2017 | Kenmore Sewing Machines
The needle thread do not cath the other thread to do the looping anymore? This matter occur after a major fabric jam under the foot. What could be the problem?
The most likely culprit is timing. Severe fabric jams tend to cause slippage of linkage connecting loopers to the drive shaft. The timing will probably need to be adjusted. If you have the service manual (not the owner's manual) and tools you can attempt to make this adjustment yourself. If this is outside of your comfort zone, please take your machine to a qualified sewing machine technician.
May 16, 2011 | Euro-Pro 100-545 Mechanical Sewing Machine
Bobbin thread and needle timing
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher and the needle is on it's way up.
Kent
Mar 21, 2009 | Sewing Machines
Bobbin?
DO NOT RESET THE TIMING!! The timing is off on maybe 1 in 100 modern Husqvarna machines. For the user to change the timing is turning a simple fix into a complicated and expensive fix.
If the top thread is "looping up on the bottom" then you have a problem with the tension on the top thread. Here is what to check:
1. Thread the machine all the way through the eye of the needle. Don't go under the foot.
2. Pull the tread to the side. While pulling, lower the presser foot. You should see the needle bend as the thread gets tight. If not, you have no tension on the top thread.
3. With the bobbin in the case, hold the needle thread and turn the handwheel to bring the thread up. Watch through the cover to see if the thread passes over the bobbin from left to right. When it gets to the right side, the take up lever should pull the slack out and the thread should be pulled up. If it comes part way across but does not pull up, make sure the thread is in the take up lever. If you never see the thread, remove the bobbin case and turn the hand wheel. You should be able to see the hook pass behind the needle while the eye is still below the level of the hook. If the eye is above the hook as it passes the needle from right to left, then and only then consider timing the machine. If the hook passes above the eye but doesn't catch the thread (bobbin case out, needle plate on, presser foot down) you probably have a problem with your needle. Put in a new needle and make sure that the flat side is to the back.
99% of the time when a Husqvarna is not picking up the bobbin thread, something simple has been overlooked. Your symptom of looping on the back of the fabric indicate either a threading or tension issue in most cases, not timing.
Aug 04, 2008 | Husqvarna Viking 1
Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Feb 01, 2008 | Sewing Machines
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
