Question about CookTek MC1800 MagnaWave Single Induction Cooktop
MC 1800 no lights or fan
MC 1800 cookTek has power it no lights or fan
Electrolux induction hob stripdown
there should be screws at the back loosen then push forward and that should do it x
Sep 25, 2012 | CookTek Magnawave 3500W Single Hob...
How to repair the twoo burner cook tek not functioning?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 01, 2010 | CookTek Cooktops
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JED8430BDB blowing fuse following ceiling fan work ...OUTside!
You have posted this to a public webpage that has 7 million visitors and is nothing to do with your electrician 'Eddie'. You have also posted your telephone number and email address to those 7 million viewers.
Feb 27, 2017 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Electical problem?
You really shouldn't have tried this. If you mixed up the neutral and hot wire YOU COULD HAVE BEEN KILLED!!!! You also could have burned out the fan motor. The fan operates on 120 volts the rest on 220. On most cooktops the frame is grounded to the neutral. If you connected this wrong the entire outside of the cooktop could be live. You might not be shocked if you have on rubber shoes but if you touched the stove barefooted you could be killed! The house wire should have 2 hot wires usuallly black or red. It really doesn't matter which is which. There should be a neutral (usually white or bare) There can also be a seperate ground wire (usually green or bare) If only 3 wires from house connect the white and green together. The minimum wire size should be #10 fused at 30 amps. Test the voltage between the 2 hot wires. It should be 220. Between either hot wire and neutral or ground should be 110 volts .. IF YOU DON"T KNOW WHAT YOU ARE DOING CALL SOMEONE ELSE. This is very dangerous if hooked up wrong.
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
CookTek MC1800 MagnaWave Single Induction Cooktop Logo
73 people viewed this question
Top CookTek Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a CookTek Cooktop Expert? Answer questions, earn points and help others
