Question about Microwave Ovens
Panasonic Microwave completely dead
I have a Panasonic NN-C2003S oven which stopped working during the night. No display and no action anywhere. I took it to a repair shop and they said it had a faulty PCB, but did not tell me which one. They said the part was no longer available, but I know there are control PCBs available for this oven. Can the components on either of the PCBs be changed if faulty? Which PCB is it likely to be? Thanks for any help.
SOURCE: Panasonic Microwave inverter oven model,
10 Amp fuse blown inside oven.
Posted on Apr 19, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
hi i have the panasonic combi and on the microwave it will work for a few seconds and then stop and on the screen it shows h98 please help
Posted on Sep 13, 2008
  • 9098 Answers
SOURCE: operates for 3 seconds on microwave then stops
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 16, 2008
  • 9098 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
Posted on Jan 23, 2009
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
How, where can i buy a ring roller for a panasonic NN-C2003S?
Fixya is unable to suggest Panasonic parts sources.
Mar 17, 2018 | Panasonic Microwave Ovens
Panasonic NN-C2003S microwave is completely dead. No lights, no action. Have taken cover off and checked fuse, which looks like it is in good condition.
Would need to check power to main board. A lot of times it is the small low voltage transformer on the main board. If the primary winding goes bad it cant get power to the rest of the board to function. So to start, is there power getting to the low voltage transformer on the main board??Have you had any thunder storms or power surges at your home where it is plugged in? If a home loses its Neutral power line it can mess up a lot of electrical devices in the home. do you notice your lights browning at times. If so you may need to get your power company out to do a load test on you system. But the transformer is a very low amp device and will not blow the main fuse if it goes bad. So you could bhave aburnt trace on the back of the main board or a bad transformer. Best guess. Good luck
Jun 26, 2017 | Panasonic Microwave Ovens
Where can I get the membrane and digital unit board for model NN-C2003S? Please provide the website.
If you can tolerate the time and cost of international shipping, contact
They repaired my 20-year old wall oven control board and shipped it back to me with 1 year warranty. Works like new.
Jan 19, 2018 | Microwave Ovens
Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
Try a reset by:
- unplugging power for a minute
- plugging it back in
- setting the clock
- trying it again
If that does not fix it, see your owner's manual to see if it can be adjusted (usually not).
If you still have trouble, you should call for service.
Jan 08, 2013 | Microwave Ovens
Inside the NN-C2003S microwave on the right hand side is a paper like material that has deteriorated (90 mm long and 30mm high) and exposed an opening. Where can I buy a replacement cover or can I use...
It's made of milar from memory. 4 years ago I needed a new one as well as a magnetron and the ceramic tray, and even though I live in Sydney, LCS Electronics in Western Australia were by far the cheapest for the parts. Back then I think the milar was around $8.
Apr 01, 2011 | Panasonic NN-T888S Convection/Microwave...
I have a Panasonic NN-C2003S microwave/convection oven that won't heat anything under micropower mode and on countdown cuts out when it gets to 8 sec. It is working on the convection mode. Could someone...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
