My seagate goflex desk 4 tb was running fine but out of sudden inbetween it started making clicking sound n stopped responding Sinse then it makes sounds n not detected in my pc n also in disk management My hd shows white light constant on and when after it stops clicking then my pc sounds a noise same as if the usb is plugged in One thing I noticed is that Aftr this when I shut down my lappi the lappi is stuck on shutting down and as soon as I unplug the usb of hd it shuts down fine Plz help I hv very important data with I work on
    Problem Solver:
  • 5 Answers
Hard drives can click for a couple of reasons, 1. the hard drive is not getting enough power to spin up correctly and 2. the hard drive has crashed totally which in fact can be fairly costly if you need data rescued from it - try another USB cable from the hard drive too as this may help.
Posted on Mar 31, 2014
dodgecharger
  • 254 Answers
SOURCE: Data recovery from External Usb Hard Disk
Fixya has received a growing number of USB connected Hard disk failures in recent months. It would appear they are a poor backup device, at least over the long term.
A couple of possibilities: First, disassemble the drive enclosure, and check the connections to the drive itself. I've seen one instance where an internal connection was just loose enough to cause a problem.
2. You could try removing the hard disk from the enclosure, and installing it as a second drive in a standard desktop PC. Interfaces must of course match- assuming it is an IDE interface, install it in a desktop with that drive connect system.
Master/slave jumpers must be also set correctly.
After this, using the drive management tool in Computer Management, try mounting the drive.
Beyond this, data recovery could be difficult at best. There are data recovery services available, but such is fairly pricey. You will have to decide just how valuable your missing data is.
Posted on Nov 27, 2007
Benimur
  • 6966 Answers
SOURCE: seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 17, 2008
  • 5 Answers
SOURCE: Western Digital 500GB My Book Essential won't start up
To save your data from a bad Wd Ebook you need to download UBUNTU and burn it to a cd. Boot from the cd. Do not install Ubuntu just click try it out. When it loads turn on your Ebook and iit should appear on the desktop. If not click the places tab on top and find it there. Right click the EBook and mount it. Now you have access to all the data on the ebook. Iy yoou have enugh space n your cpu hard drive save it there, if not you will need another surce large enought to copy the data to.. I have used this method to save many hard drives, flash drive and other unreadable media. if the drive is totally toast you are out of luck but this method works moost of the time. Any questions drop me an email.
Shayne
Posted on May 01, 2009
  • 62 Answers
SOURCE: External Hard Drive has stopped being recognized
First thing to do is to try it on another computer to see if its not your windows playing with you.
If that doesn't work its either the USB controller inside your Hard drive box or the hard drive itself.
The only way to figure it out from there is to open the Hard drive case remove the Hard drive and either try it with another usb module that you know works or plug it right in the computer with IDE or Sata interface.
Posted on Jun 01, 2009
I am so happy to say that i HAD the exact same problem.
Its an issue with the drive disk itself. Long story short because i dropped the drive the the disk was no longer able to spin fast enough to start the drive (the beeping sound actually being the disk trying to start spinning.
After spending literally the last 4-5 hours looking for a solution I found a unusual method that basically either works, or it doesn't there's no it kind of works. what you need to do is unplug the drive, then plug it back in and start Vigorously spinning it whilst keeping the drive horizontal (similar to what you would do when your unscrewing a light bulb).
You have to try and do so simultaneously with the beep and it should "kick start" the drive (AND OBVIOUSLY DON'T LET THE WIRE DROP OUT AS YOUR SPINNING IT AS YOUR COMPUTER WONT RECOGNISE IT IF ITS NOT PLUGGED IN).
I Know this method sounds far fetched but put it this way, 15mins ago I was working out how im gonna get hundreds of pounds to restore this drive, Now, i've just finished copying my informations onto a laptop from the drive so i can take this piece of plastic **** back to the shop :D.......
Never again Seagate and Thank God for letting me find a solution.
Posted on Jan 24, 2011
Why does my Seagate FreeAgent GoFlex, 1.5 TB, external hard drive USB 2.0 make a clicking sound and will not connect to my Satellite receiver?
Does the drive work with a computer? This is an important test to determine if the drive is bad, or if it is an interface problem. Check the satellite receiver instructions for using external USB devices. Many times, these types of devices do not have interfaces with drivers for external hard drives.
Jun 03, 2015 | Seagate FreeAgent GoFlex Desk 1.5 TB USB...
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Oct 29, 2013 | Seagate FreeAgent GoFlex Desk - 1 TB...
Seagate goflex desk 1 TB wont turn on
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 27, 2012 | Seagate Freeagent Goflex Desk 1 TB Desktop...
My Pc's, one have windows xp, the other, with windows 7 Home P, not reconized the External Disk FreeAgent GoFlex Desk of 2 Tb. Please, help us. Thanks
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 18, 2011 | Seagate FreeAgent GoFlex Desk 2 TB USB 2.0...
I want a users manual for my seagate freeagent goflex desk hard drive 2 TB.
Go to www.seagate.com and look for your particular model of device. They should have all of the text for you to download.
Their website is pretty easy to use compared to most, but you can also do a search of your device in their search page.
Thanks,
Please Rate.
Jul 08, 2011 | Seagate Computers & Internet
Hdd seagate 2tb suddenly not work i connect and the light flash and my pc and mac dont read the hdd pplease help
Hello OS,
The GoFlex Desk external drive have ample storage capacity and it's easy to upgrade to any interface you need.Pairing the desktop hard drive with a GoFlex USB 3.0 or FireWire800/USB 2.0 adapter to increase your performance by up to 10 times. Works interchangeably between a PC or a Mac® computer.
Please visit the link provided below :
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=214431&NewLang=en
Jun 07, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I have dropped a Seagate goflex desk 2TB hard drive and when I power it, it makes a beeping sound, like a siren.
hello vyseman15,
hard disc drives need to be handled carefully, they can only handle a limited rough usage. especially dropping while it is working is very dangerous, in most cases the head will "scratch" (damage) the discs surface which make the device afterwards useless.
sorry to say there is nearly no chance to make it work again. there are some companies who can rescue some of the data on it, but they are expensive anyway.
regards
Jun 07, 2011 | Seagate Freeagent Goflex Desk 3 TB Desktop...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
