Question about Crock Pots & Slow Cookers
Tv says asm after 3 sec
Tedelex tv model ec 2978 switch on and of by it self
Need replacement lid for Rival Crock pot Model 5070. 13 1/4" x 10 1/4"
Hi, for the oval lid (SCVS600) for less than $2.00, buy two 3/4 " long stainless steel #8-32 round head (Phillips) screws with self-locking nuts. Using a 5/32" drill bit, drill a hole through the handle at each of the two locations in the handle where the original threaded inserts were located (they are probably out since that is where the handle probably broke). (NOTE: Drill the hole in the handle at the same angle that the original screw makes with the handle because of the curvature of the glass, so that the new screw head will still set flush against the glass.) Using the original inside washer from the original screw, re-assemble the handle onto the lid. The 3/4" screw will not extend out past the top of the self-locking nut - it will sit below about 1 - 2 threads - but that's OK. This sould never break again.
Apr 30, 2011 | Rival 38601 Smart Pot 6-Quart
Still very new Tedelex pressure cooker: the red-headed pop-up valve seems to take for ever before "popping" and allowing steam pressure to build up. How long should I wait? Thanks, Nic
My pressure cooker does that too, you would have to wait until the steam starts to come out a lot, then it will pop out and start building up pressure. Hope this helps.
Apr 08, 2011 | Crock Pots & Slow Cookers
Rival crock pot smart pot - low, keep warm & hot lights blink and pot will not heat. is there something i can fix or is the pot destined for the garbage truck?
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Aug 08, 2010 | Rival 38601 Smart Pot 6-Quart
My smartpot shut it self off and wont turn turn back on
try holding the reset button down, plugging it in, and then releasing it after maybe 5-10 sec.
if your familiar with computers.... try repeatedly pushing the reset button as you plug it in... kind of a total reset
other than that it sounds like a glitch.... how long have you had it.... Mmm, consider calling the company and explaining complete mechanical failure. Hey, you never know if you don't try. Happy Holidays... best of luck
Dec 24, 2008 | Rival 38601 Smart Pot 6-Quart
Crock Pots & Slow Cookers Logo
29 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
