Question about Precor 9.21 Treadmill
Treadmill does not switch on at all - Precor 9.21 Treadmill
Treadmill LS10.0T Runs & inclines When slowing down treadmill it will shut down, the power switch is in 'On' position but light on switch goes off and back on. Is this a switch issue or a motor issue
Check the wiring from motor control board to control panel.
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 27, 2016 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Treadmill
Reset the treadmill and try again. God bless you
adjust the REED switch, see the diagram, clean it, test for open or faulty, tight the connector very well. and try again.
Jun 16, 2013 | Exercise & Fitness
Treadmill error code 68
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
GE3100T treadmill stopped working
HI,
All the treadmills have a power switch with Auto reset. If there s any overload detected it will automatically reset to off position To prevent any further damages. Just check the power switch of the treadmill. If its it off position then turn it one and check the treadmill. If the switch again rest to off position then try to call for a tech to repair the treadmill.
Ajin
Feb 23, 2013 | Exercise & Fitness
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    Precor 9.21 Treadmill Logo
    18 people viewed this question
    Top Precor Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Shehu Pro
    Shehu Pro
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
