Question about Parrot Ck-3100 Bluetooth Car Kit Chrysler Sot-086
Calls muted when answered
I recently had my car kit installed into a different vehicle. Every time I answer a call the car kit seems to mute calls and switch them over to my cellphone. I am using a Samsung Galaxy S3. Any ideas about what the problem maybe would be appreciated. Thanks Justin
    Guru:
  • 274 Answers
Dear Justing,
Thank you for contacting fixya. Press volume up buttin while calling.
Posted on Mar 31, 2014
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
I have an audi a3 2005 but my CK3100 wont mute when taking calls??
Has your 3100 ever worked correctly since being installed? Can you give me more information about how it was installed (professionally or by your self)? Often times when these are installed the mute wires get connected (Mute 1, 2, and 3). These are unnecessary and will often cause problems because many stock radios don't have a dedicated mute wire. If you are able to get to the wiring disconnect and tape up the mute wires. Did that solve the problem? If not and if this also came on after a time where the Parrot worked correctly, it could be the blue box or the mute cable (the one with the wires that go to and from all the speakers with the black box on it) have gone bad. I've installed many of these without issues. I've also had to replace brand new ones after people installed them and connected the mute1, 2 or 3 wires. If those mute wires are connected to the wrong wire in the vehicle it can allow current to flow into the device causing it to damage itself damaging itself.
Let me know if this has been helpful
Ray
Mar 01, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How do you answer a call on a BB 7290?
This is the instructions in making callsand answering calls and how to mute a call. Making Calls Input the desired phone number into thekeypad, then press the "Enter" button to initiate the call. Press the"Escape" button on the right side of the device to end the call. Tap"Answer" to answer a call or "Ignore" to reject an incomingcall. If you are on a call, tap "Answer --- Drop Current" to end acurrent call and answer an incoming one or "Answer --- Hold Current"to place the current call on hold and answer the incoming one. Press the"Phone" button to mute a call.
Jan 08, 2011 | RIM BlackBerry 7290
Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Feb 11, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
'Yellow Wire - Stereo Connection???'
Yellow wire connects to the music mute wire on the back of the car stereo (usually brown). This will mute the stereo when the hands free is in use!
May 28, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
Mute button wont turn off
HERE is your manual in PDF format.
This unit doesnt have a volume mute function.
What are the problems you are experiencing.
If it says Mute or ATT on the display - it is the cellular mute function turning off the volume for an incoming call.
Page 34 details turning on and off the cellular mute function.
You also may try a hard reset by removing the face, and pressing the reset button.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
May 06, 2009 | Audio Players & Recorders
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Jan 05, 2008 | Panasonic KX-T7453 Corded Phone
Parrot Ck-3100 Bluetooth Car Kit Chrysler Sot-086 Logo
51 people viewed this question
Top Parrot Cell Phones Experts
Andrew Wright
ray gallant
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
