Question about Miele Washing Machines
How do you take dryer off top of washing machine
T8423c dryer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Go to this web site-
how-2-repair.com
Posted on Mar 31, 2014
Wont drain or rinse
this may be of some help
4. WASHING MACHINE REPAIR GUIDE
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/washing-machine-washer-dryer/2967-washing-machine-a-washer-dryer-top-problems-a-common-cures
5. FIVE MOST COMMON PROBLEMS WITH A WASHING MACHINE
https://www.youtube.com/watch?v=-4j8RoesBrg
or go to my tip for more help re washing machines
good luck
Nov 23, 2016 | Washing Machines
Can i stand my Stirling dryer on top of my Stirling washing machine
Other than marring the finish and having the vent hose being seen, or not being able to use the controls. No.
Mar 28, 2014 | GPS
Miele Softtronic T8423C only blows cold air..
If you are fairly sure that the power is reaching the clothes dryer, and the clothes drum is spinning, unplug the dryer first. Then using a continuity checker check the heating element. very often if the element needs replacing you will notice a break in the coil. Just like a light bulb, the heating element will eventually need to be replaced. The coil is the only source of heat, although it has components that operate it .
Dec 05, 2013 | Miele Dryers
Can I stack my bosch wfk 2401 on top of my bosch wtl 5400
I wouldn't. Not without a proper shelf for the washer.
Washing machines are heavy because there's a huge lump of concrete placed over the drum to dampen down any vibrations. A tumble dryer is hollow, has little structural strength.
Put the machine on top of the dryer, you're going to get a crushed dryer if not a crushed foot, leg or child. Please be very careful.
Nov 11, 2011 | Bosch WFK 2401
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
The water in my stackable washer and dryer wont drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Separate miele washing machine and dryer
if you go to sears .com click on parts put your model number in(should be inside dryer door)it willl break down and show you everything you need to know,let me know how it turns out,mike
Sep 28, 2008 | Miele XLWDSTAND Washer and Dryer Stand
No Heat during washing or Drying
they are totally separate systems
for drying
one of the stats on top of the dryer manifold is usually a resettable type ie has a little button in the middle of the top. press this button and chances are dryer will work. an alternative method of guarding against overheat used by hotpoint, is a thermal fuse located on top of the dryer manifold. this may be open circuit. it is unusual for dryer heaters to go open circuiit but it is possible so that needs checking as well.
if a resettable stat has popped, the cause is often a lint build up in the dryer duct so if you get dry heater working and fault reoccurs, you must check for lint blockage in the dryer duct
for wash.
take rear bottom panel off and heater is slightly to the rhs. you will need to check for continuity in the heater. if you are unsure if the wash heater is working or not, put machine on the hottest wash and you can check if heating
good luck
doug
Aug 09, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
22 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
