Question about Ovens
Baumatic bt2760ss hi i m looking for wiring diagram can u help me thank you
2 Suggested Answers
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
No power to my oven
Start at the breakers and then test the wires coming into it. If power there then its in the wiring on the unit. I would test at the switch, and look for shorts. This is danger if your not trained in handling 220 volts. Be careful
Jan 07, 2015 | Baumatic Ovens
I need to find a a schematic wiring diagram for baumatic bce520sl electric oven
If its a short it usually leaves a trail to follow. If its a short to ground the shorted terminal will be blackened and you will usually see residue near the shorted area. If two or more wires have shorted together they will usually be welded to each other or at the very least the insulation where they shorted will be burned. Look for these tell tale signs of a short, or any other signs that look like they don't belong.
Aug 10, 2014 | Baumatic Ovens
Baumattic Bt2760ss oven trips power
Check fan to see that it spins freely. Look for any evidence of rodent nests or damage( chewed wires ) check breakers and wiring to make sure they are properly sized for the oven. Hope this helps.
Jan 18, 2014 | Ovens
Hi I brought a Baumatic Microwave model GEM252TK and I need the spec to fit it in to my new kitchen and I cant find it cheers
You can download a brochure - with the dimensions of the microwave - free from here:
http://www.baumatic.com.au/smart/media/Baumatic_2010.pdf
The dimensions are at the bottom of page 25. You can view, print and or save this file. If you need the general specs e.g. power rating/features, you can find them here:
http://www.baumatic.com.au/smart/25l-microwave-oven-with-grill.html
Please rate this solution if you find it helpful. Thanks.
Oct 23, 2010 | Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Dec 07, 2008 | Baumatic Ovens
Baumatic oven not heating up
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Jan 13, 2008 | Ovens
Sep 18, 2007 | Ovens
Ovens Logo
15 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
