Question about LG Le2104d Security System Dvr, 4 Ch, 500gb Hard Drive
Reversed polarity on lg le-2104d dvr now no screen
Power light on but dvd drive doesn't open or hd power on
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
Accidental reversed polarity with an external hard drive
if the board is fried, you can take the platters (discs) out and put in another HD of same make and model to recover data. Will require special tools and patience. Its the only way I know to recover data from a blown HD. PS, use vinyl gloves as to not leave finger prints. and do this in the cleanest area you can find! Im not sure how you managed to reverse the polarity... hope this helps...
Oct 01, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Power supply for the 2nd screen ??
If you are not using the car power adapter that came with your PDV-768 for the 2nd screen, you are likely running into the possibility of "reversed polarity" with the power adapter you are attempting to use. This can & often will cause a problem with your unit.
Nov 28, 2007 | Protron PDV-768 Portable DVD Player
LG Le2104d Security System Dvr, 4 Ch, 500gb Hard Drive Logo
13 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
