Have a TEAC 2300 S and the reels don't turn like it's not getting electricity. Can anyone help? Everything else works ok
Could it be a fuse? where would I look? The main fuse is ok
  • Audio Player... Master
  • 1,258 Answers
Hi Roy,
It can be a number of things but the brake pads are one sure guess. I have been working on these for better than 40 years and an a past Teac Lead Technician from Chicago factory service.
I am in Chicago area but if you contact me i can direct you where to go or fix it myself. skywavebe at sbcglobal dot net.
Posted on Jan 02, 2015
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Posted on Jun 20, 2008
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
  • 104 Answers
SOURCE: teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Posted on Feb 11, 2009
  • 141 Answers
SOURCE: I have a TEAC reel to reel stereo tape deck, Model
That's a rarity but easily fixed. Before pulling anything apart spray some penetrating oil (WD-40) or similar into a small container. Then with a cotton bud soak the tip in the penetrating oil and apply it to the base of the capstan where the bearing is. Allow this to sit for a few hours and even repeat it if it looks to have soaked the oil up. NOW, with the power lead out of the wall socket remove the top cover of the deck. You will have to remove a few knobs and mode switches too. Now see if you can rotate the capstan flywheel by hand. It might take a bit of pressure to get it to turn but once it does keep going until it starts to rotate freely.
By the way, check that the capstan drive belt is in one piece and not slipping first.
If it's running freely then reassemble the cover and other pieces tyhen put a few drops of light oil on the capstan bearing (sewing machine oil is ideal) Do this because penetrating oil will dry out after a while. That should fix it.
I'm assuming you know exactly how to thread the tape through the machine. Don't forget to position the stop lever on the upper side of the tape otherwise nothing will operate. If you are unsure about that write back and I will elaborate.
Posted on Apr 24, 2010
Looking for a Teac X10 reel to reel recorder User manual Not service manual Can anyone help please?
It should be found as a Pdf file on Hi FI Engine or for $5.00 at owners-manuals. com as these places usually have the common manuals.
Mar 19, 2015 | Teac Audio Players & Recorders
FF problem on Teac Reel to Reel
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old.
I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
Jul 15, 2013 | Teac Audio Players & Recorders
Teac A-5300 reel to reel service manual
Try Hi Fi Engine first and then owner-manuals.com and the best solution is from stereomanuals.com which is where I get my manuals.
http://www.stereomanuals.com/index.htm
Jan 04, 2013 | Audio Players & Recorders
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Threading Diagram
Send me a picture of the front of the deck and I'll mark the picture with the threading pattern, and e-mail it back. ****@rsaaa.com
Jun 12, 2008 | Teac Audio Players & Recorders
Teac X-10 connections to a dbx 224
connect the x10 outputs to the dbx 224 line in connect the dbx 224 outputs to the cd recorder anlog line in windman
Jan 29, 2006 | Pioneer PD-R509 CD Recorder
 Grubhead
Grubhead
