Question about Video Cameras
Thermostate showing clock error ac not working
AUG30ALD_W
Carrier FCU A.C thermostate E4 error coming PlZZ tell me what solution??
Do you have a model number for the equipment in question?
Aug 04, 2016 | Carrier Heating & Cooling
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
O general cassette type air conditioner error code
what is the problum in ac if showing thermostate clock error.we already we replaced main pcb and filter board .
Mar 22, 2013 | Heating & Cooling
Temperature control not working properly
It could be ur thermostate, that was happening to my 94 lexus es300, and the gasket was stuck in thermostate preventing it from opening up all the way, that or ur heater core needs to get flushed, what temp does ur gauge say inside the car?
Oct 07, 2012 | 1994 Lexus Es 300
13500 dometic ac for rv with anilog thermostat
My Unit is only about 5 years old; but it's working great now. I spoke to a man at an RV service department, he suggest replacing the thermostate and Jay box, which is the box inside my roof unit, accessable when I remove the filter. When I replaced the thermostate nothing changed, but the Jay box did the trick. The Jay Box came with a new thermostate anyway, and cost around $80. Good Luck
Feb 18, 2009 | Dometic Rooftop RV Air Conditioner
No power to thermostate on Duo Therm 15000
Look for a small fuse somewhere in the control panel. Usually a blade type (car) fuse 3 to 5 amp. Chack to see if its blown. If you have no fuse, or its NOT blown. Check to see if you have voltage comming out of, and going into the transformer.
Thsi is where you would START to diagnose the problem. Check this and we can go further.
Jan 18, 2009 | Dometic Rooftop RV Air Conditioner
FUJITSU AIR CON
fujitsu tech line # 866-952-8324 very good ac dan
Aug 01, 2008 | Fujitsu Heating & Cooling
Service problem
This code is a fuzing unit code , one of your thermosters are busted or dirty so it is not picking up the heat correctly , ill sugest you take out the fuzing unit and clean both thermosters and try again , but you need to reset the code after cleaning the thermosters by pressing :yellow c 107 and hold down orange c until it shows copy sp mode press 1 # then turn the power switch on and of hope this helps
Nov 05, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
Video Cameras Logo
18 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
