Question about Miele Dishwashers
Water will not flow into the G 650 SC dishwasher. Power comes on and the dishwasher hums away but there is no water getting in - Guess it's the Solenoid on the tap end of the hoes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Could be a loose connection on top of the solenoid or a faulty coil on the solenoid if it's humming it's probably a faulty coil, contact Miele at fern tree gully rd scores by they will be able to send out a new coil for you, you need to be aware there are two different sorts of coils they go by colour either grey or red.
I hope this helps
Posted on Mar 31, 2014
Amigaman
  • 248 Answers
SOURCE: Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Posted on Nov 09, 2007
  • 351 Answers
SOURCE: Problem with Miel dishwasher: no water
if the valve is humming and the tap is on it should fill.is there a plv fitted to the tap somtimes they fail.i had one today on an asko for not filling.remove the hose from the dishwasher and turn the hose on into a bucket to see if water comes through.the valve could still be faulty.hope this helps.
Posted on Mar 20, 2008
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
  • 236 Answers
SOURCE: Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Posted on Mar 16, 2009
  • 221 Answers
SOURCE: Dishwasher top spray bar does not spray due to low water fill
Check the water hose going from the sink to the dishwasher to make sure it is'nt clogged, if there's a water shut off valve under the sink make sure it's fully open, also check to make sure the spray arms at the bottom of the dishwasher that supply water to the top rack is clean with no debris or obstructions in the spray hole's, the water entering the dishwasher should be at a warm temp, if it's cold the dishes will not get clean, you should have good water pressure from the house supply for it to fill properly, the float is also called a flood switch, it should not be activated during the water fill cycle, if it's activated it will shut off the water inlet valve and the wash cycle will stop or the dishwasher will drain, if your still having wash problems it could be a defective water inlet valve or a bad timer, if that's the case you might have to call an appliance repair man, hope this helps, good luck.
Posted on Mar 28, 2009
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
When a setting is chosen it makes a humming sound and stops water does not run or drain.
Hello & Welcome to FixYa
If the hum sound is coming from the bottom panel then it is the moto that has gone bad and needs replacement. However, if you hear the sound from the control then it can be due to a bad relay in the control and it is recommended to replace the control completely. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Maytag MDB7100AWB Dishwasher
My dishwasher is just humming and giving off just a mist in the dishwasher. The water is not flowing so therefor it it cleaning or rinsing dishes
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 19, 2010 | Dishwashers
Dishwasher does not fill with water. It hums as if it is trying to work.
If there is water in your inlet and on switch of program there is water coming into the washer, it is possible that the Hum you are hearing is the inlet valve/pressure pump that is not activating.
It might be getting warm if humming for a while and you can check this out. Remove the unit and checkit out onthe table by applying voltage for the water flow or pumping. Dirt accumulation can make it stuck and if not replace .
Sep 17, 2010 | KitchenAid KUDS50SVSS Builtin Dishwasher
No water
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
May 28, 2010 | Caloric 24 in. CDU300C Built-in Dishwasher
Mar 16, 2009 | Dishwashers
My dishwasher is not filling up with water?
If the water seems to be flowing in slow, I would turn off your water supply to your dishwasher, then disconnect your water line to your inlet water valve, then check the screen on the inlet water valve, its most likely clogged.
Jun 13, 2008 | Dishwashers
Dishwasher keeps stoping
Favorite for bosch is the water inlet modual which monitors the water flow in could be faulty, If incorrect pulses take place the motor wont proceed. Otherwise listen for a hum after water stops filling. If there is a hum, the main wash pump is jambed and has to be sorted out.
Jun 08, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Mar 19, 2008 | Dishwashers
Dishwashers Logo
66 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
