Question about Toshiba TDP-T9 DLP Projector
My fan keeps going on and off
WHEN i start my projector it come on and goes off bse of the fan
    Problem Solver:
  • 6 Answers
I had one do this in the past. I ended up using an air can to free the fan parts of dust. Have not had an issue after that.
Posted on Apr 02, 2014
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
We have Toshiba TDP-T05 projector - recently replaced the buld - projector starts then does not work red indicator on Fan and on button - looks like Fan bad. Can this be fixed or better to buy new.
Before going to by a new one just try to do the following
First of all try to reset the lamp hour of your projector. For resetting the lamp hour do the following.
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on,
Otherwise Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projecto and watch.
ok
Mar 07, 2011 | Toshiba TDP-T95U Multimedia Projector
Fan keeps running on a Canon LV-7345 projector, also how to fix the picture shadow
does the fan keep going when machine is switched off? if you mean its going all the time whilst on let it dont worry its probably good for it.... if the fan continues to go after switching off it could be that the fan will not switch off till the bulb has cooled to a certain point.... picture shadow should be able to be fixed in the menu on the projector. hope this helps
Feb 25, 2011 | Canon LV 7345 Multimedia Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
MY 3M MP 8640 PROJECTOR GOES ON FOR 3 MINUTES THEN THEN TEMP LIGHT GOES RED & THE PROJECTOR STOP
clean the dust out of it with canned air and make sure the fans all spin. the dust keeps in the heat that the projector is trying to expel.
Jun 27, 2009 | 3M MP 8640 Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Quantum Apollo 16000 Portable Projector
It sounds as though the unit is overheating. That would explain why the fan keeps running, and once it cools down enough it starts up again. What kind of environment are you running this in? Is there a way to put it in a cooler environment? Even having an external fan blowing on the unit could help. Honestly, unless you've got it in a very hot environment, it also sounds like a poor design for heat dissipation. Or possibly the heat sensor is bad, and shutting it down at a lower temperature than it should.
Aug 28, 2007 | Quantum Apollo 16000 Portable Projector...
Toshiba TDP-T9 DLP Projector Logo
27 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
