Calcom tv C25N2V3.PCB/040120284
Audio noise or vertical out problem what i do?
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Mar 31, 2014
2 Suggested Answers
gopakumarg43
  • 74198 Answers
SOURCE: I had replaced my Samsung
Hello
Your TVs Calcom board has vertical output problem I thinks. I don't know where you are in Trivandrum. I'm also from Trivandrum, Karakulm. I don't know why the person who fitted it refuses to recive it for service. Sometimes he would have a doubt about its chroma jungle Ic TDA 9370/PS/N3. If its so It is available in Trivandrum now. If you don't mind call me on 04722887916 after 8PM. and let me know your problem. OK.
Posted on Dec 09, 2010
While watching TV or even when all components (except the Denon receiver) I hear random noises through speakers. What could be causing this?
Your problem could be a bad dsp processor which is on the hdmi pcb, change that pcb and the problem should quit
Apr 04, 2015 | Denon AVR-E400
TV screen is all vertical and horizontal lines, sound works
most likely t-con PCB pt# BN81-01692A $56.32 at this site: https://www.encompassparts.com/model/SMGLN40A330J1DXZA/_/_/Samsung/LN40A330J1DXZA/TELEVISION
BUT BE SURE TO USE YOUR COMPLETE MODEL\SERIAL NUMBERS TO VERIFY CORRECT PART#
$19.34 THIS SITE:
http://www.shopjimmy.com/catalogsearch/result/?q=BN81-01692A
Jan 08, 2014 | Samsung LN40A330J LCD TV
I locked calcom TV and how can I unlock it?
Write your answer...my tv lock calcom
Oct 20, 2013 | Sanyo Televison & Video
Calcom philips component tv kit having vertical line problem
iam fixed calaom tv kit in toshiba 21 flat tv there is a problem in picture vertical height is less what can ido
Jun 03, 2012 | Televison & Video
I have a 40" tv
Hello, try this:
open the rear cover, check the connection between the PCB and PCB T-Con (pcb attached to the panel). open and clean the socket on the PCB T-con. If still lines appear , I think the problem comes from the PCB T-con.
Contact service center to repair your TV set.
Mar 14, 2011 | Samsung Televison & Video
I had replaced my Samsung TV with a Calcom Printed circuit board about 7 months back. Now only a vertical 1/3 part of the picture is seen and it is shapeless too. No audio is coming out. No service...
Hello
Dec 09, 2010 | Televison & Video
Mitsubishi 55 inch Digital TV WS-55807
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55807 TV
Mitsubishi projecion tv 1995
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Self-diagnosis error 2-3 indicating deflection failure. Check for shorted or leaky Q5A37 part # 260P818050 located on PCB-Main. If found defective replace only the transistor instead of the Main PCB.
Sep 16, 2007 | Mitsubishi WS-65615 65" TV
Mitsubishi tv 52'
CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB. 2. VERTICAL BEAM BLANKING ACTIVE, CHECK PIN 4 OF IC401 FOR 3 VDC IF MISSING CHECK IC202 (5V REG) PART # 266P932010, ON THE SIGNAL PCB. 3. CHECK PIN 6 OF IC200 FOR 9 VDC IF LOW OR MISSING CHECK IC203 PART # 270P210010 ON THE SIGNAL PCB. 4. MAY BE INTERMITTENT. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. Now these are the technical terms, if you do not have the experience you may need a qualified person to do this. Hope this helps
Sep 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Sony KVTS27 audio noise and pops
your problem is a stand-up printed curcuit pcb it has several mof those small surface mounted caps that always goes bad and the # on the part is SBX1981or SBX1981-51p its part # is 874213400 its about 11 to 15 bucks . Dont try to repair the part as the pcb is eaten up from the caps leaking all over it. Good Luck
May 06, 2006 | Sony KV-27S42 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
