Whirlpool awg 354The water pressure from the hose in the middle canal in the plastic drawer is very weak pressure, therefore the 1 hr washing cycle is taking 2+ hrs washing time.. As if there is somet
Is are there any filters I have to check?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Possible hose clog. Clean filter. or go to -
how-2-repair.com
Posted on Mar 31, 2014
  • 1462 Answers
SOURCE: washing machine problem
at the back of the conditioner compartment there is a syphon. check the tube of the syphon is clear. put on rinse and at the point the conditioner should be taken, open the drawer and check that there is a jet of water into the conditioner area. if not, there are some holes in the roof of the top of the box. these may be blocked. clear with a hairpin or similiar
Posted on Apr 22, 2007
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
SOURCE: f-21 error, washer not draining
I have had this code three separate times. The first time service man came and cleaned out the filter. This is behind the lower front panel and can be removed by hand. The cartridge style filter is located at the pump in the lower right of the unit. Have something available to catch the draining water as you loosen the filter. The second time I received this code I found a blockage in the drain hose at its bend. The third time no hose blockage, no filter clogging, but the pump impeller was jammed by an elastic strap that had made it through the filter. I removed it through the supply side of the pump seen after filter is removed.
Posted on Aug 13, 2009
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
Fix washing machine
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 31, 2015 | Admiral Washing Machines
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
TIMER
Mar 25, 2015 | Bosch Washing Machines
Rinse cicle will not dispense water
TIMER
By the way my advice is free cuz God is good!
Apr 29, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Getting f20 error code, how to check flow meter operation
Check for stuck socks or something just under the door seal at the bottom of the drum. Check filter for blockage and all outlet pipes. Check the pressure switch hose for any holes as it may have rubbed on the drum and created a small hole in it. Make sure flow meter is level and not at any angle.
Dec 22, 2012 | Whirlpool duet Washing Machines
My front loader is not working whirlpool
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water overfilling in detergent tank
CHECK THE INLET HOSE UNDER THE DRAWER, PULL THE DRAWER ALL THE WAY OUT BY DEPRESSING THE MIDDLE BUTTON ON THE MIDDLE REAR OF THE DRAWER. MAKE SURE ITS NOT PLUGGED WITH DEBRIE
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have an AWG 329 washer drier. The water won't
the pump is either broken or there is a block in the drain line sadly with these ne high tech units they can break down within weeks ive seen 3000 dollar washers and fridges writen off as quality test are very weak
Apr 21, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't change the default wash cycle without it switching
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
