Question about SAMSUNG GT E2652
Bluetooth not open
Bluetooth problem not open
Laptop blutooth
Enternal or External? In the Search box type Bluetooth, if you have bluetooth software it will list it. Right click on Bluetooth and send to desktop. OR, open Device Manager, open Network Adapters OR open Services, Bluetooth, is it running? This may help: http://support.microsoft.com/KB/894035
Feb 14, 2013 | Computers & Internet
Want to use a wireless speaker via bluetooth. How do u turn on the bluetooth? I push the FN, and F3 and get 'no device'. I need to 'pair' the speaker (HMDX Jam Wireless). Well, help
Does you laptop have Bluetooth? Open start menu, search, type Buletooth, Does it come up? OR, Open Device Manager, Network Adapters, is Bluetooth adapter listed? OR, Open Services, do you see Bluetooth? If you find the Bluetooth Software, open Settings.
Feb 06, 2013 | Acer Aspire One PC Notebook
How if my Asus Eee PC 1215P there is no bluetooth but i want have it?
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Dec 27, 2012 | ASUS Eee PC 1215P-MU17-RD Netbook
How to activate bluetooth on asus k55a
Dec 08, 2012 | Computers & Internet
Bluetooth doesnt work
you need to put whatever device you are trying to join to it in discovery mode and then scan for it from your pc.
Jun 02, 2009 | Acer 4220-2346 Notebook
Connecting bluetooth to blackberry
Hi. You didn't say which Blackberry you have. I'll assume you know who to open "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your Blackberry.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your Blackberry.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Hope that helps!
May 25, 2008 | Plantronics Bluetooth Headset 610 Wireless...
Plantronics bluetooth headset 610
Hi. First the code. Almost every headset uses the code 0000 (that's 4 zeros).
Now the pairing. You didn't say which phone you are using. I'll assume you know how to get into "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your phone.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth.
Open "Options".
Back to your phone.
"Bluetooth"
Your phone will search for your headset.
After a short time, your headset will appear on your phone.
Mar 30, 2008 | Plantronics Bluetooth Headset 610 Wireless...
Bluetooth and gallery
i use that phone but never being like that.i think you should check all setting back
Jul 01, 2007 | Nokia 6600
Opening problem of gallary in my nokia 6600 phone
This is the problem due to blue tooth. If he bluetooth chip is damaged the gallery is not opened.you opened the set carefully and heat the blue tooth chip. This is the normal procedure
Mar 17, 2007 | Nokia 6600
SAMSUNG GT E2652 Logo
11 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
