Press f1 ?
Press f1 to re boot or f2 ? nothing else happens?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
If you're laptop is an HP/ compaq model, this is means that system has a BIOS password set on it.
thanks
Posted on Mar 31, 2014
ziraffa
  • 827 Answers
SOURCE: Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
Craiglloyd
  • 33 Answers
SOURCE: pc hang up at f2 after bios update
Try downgrading the BIOS to a previous version then load setup defaults. After that update it again with the latest BIOS version. If it does the same thing then the bios package that you downloaded could be corrupt, you may need to download it from a different location.
What is the model of your intel motherboard?
Thanks
C
Posted on Apr 03, 2009
  • 489 Answers
SOURCE: Bootup Problem of Dell PE6650
Your NVRAM was corrupted (probably by a dead CMOS battery) or your hardware configuration has cnaged (deah boot disk, etc). Enter setup to see if the date/time has reverted to a previous date. If so, the CMOS battery needs to be replaced and the BIOS reconfigured for the server. Otherwise, check to ensure that your disk configuration is correct. If the battery is not dead and your disk configuration is incorrect, you may have a bad hard disk.
Posted on Jun 05, 2009
SmartAviator
  • 449 Answers
SOURCE: Bootup Problem.
Try getting BIOS access by pressing F2. Then try rebooting.
Posted on Jul 17, 2009
yboyandrei
  • 828 Answers
SOURCE: I did BIOS flash update on my ASUS P5WD2 Premium
Install the BIOS Flash update, one by one. Like for example 1.0, 2.0 or 3.0.
And if still the problem consist. I think its not your BIOS problem.
Clear the BIOS by disable the JUMPER Setting.
And one last thing change the LITHIUM BATTERY(CR2032) a new one.
If you got the problem again, put a comment so that we can easy understand what is the problem with your MB.
If i am helpful, please rate me.
Thank you very much.
Yboyandrei
Posted on Aug 10, 2009
How do I go to BIOS?
You can enter BIOS setup or UEFI firmware via traditional method: Boot the PC, while the firmware starts to run, press F2/F1(Fn+F1 or Fn+F2). However, computer boots fast, maybe you often miss the trick to press F2/F1(Fn+F1 or Fn+F2). You can enter UEFI firmware from windows 8 or 8.1.
Nov 02, 2016 | Computers & Internet
Please see attached photo, this is what's
what are you trying to do ?
a bit more information might be able to help you.
IE: what are you doing when this (pop up) occurs ?
and why are striking the F1 or F2 keys ?
Computer keyboards contain keys that, when pressed on their own or in conjunction with another key, provide shortcuts to performing functions, saving time and keystrokes.
On most keyboards, these are the function, or "F," keys that run along the top of the keyboard. "F1" and "F2" are members of this group.
F1 Function Key
Pressing the "F1" function key while you are in an application will bring up the application's help file.
Pressing it when you are not in Windows Explorer or on the desktop produces the "Windows Help" file.
If you are in an application and press the "F1" button along with the Windows button, you will get the "Windows Help" file.
F1 Function Key Combined With Other Keys
"F1" can be pressed with other keys to gain a variety of results and functions.
Press "F1" and the "Shift" key to start context sensitive help, or help for the application.
Use the "F1" key with "Alt" to go to the next field in an application.
Press "F1," "Shift" and "Alt" at the same time to return to the previous field in an application.
To display the Microsoft system information, press "Ctrl," "Alt" and "F1" at the same time.
F2 Function Key Clicking on an icon on your desktop and pressing the "F2" function key will put the icon into rename mode in the same way as right-clicking on the icon and scrolling to "Rename."
F2 Function Key Combined With Other Keys
"F2" when pressed with other keys combines functions commonly found in the application "File" and "Edit" menus.
To copy selected text, highlight the text and press "Shift" with "F2."
To view a print preview of a document, press "Ctrl" with "F2" when in a document.
To save a document, press "Alt," "Shift" and "F2 together when in the application.
To choose the open file command, press "Ctrl," "Alt" and "F2."
Apr 22, 2013 | Computers & Internet
My ASUS Eee PC 1005HA turned off by itself then when I turn it on again, a screen come up and said "press F2 or tab" but when i press each of them, nothing's happened. How can I fix that?
Hi I have almost the same problem as ame_91_ok with my Asus Eee Pc 1005Ha. It suddenly shut down a few days ago and ever since that time it boots the bios screen where you have to press F1 to enter setup or F2 to load with the default settings. If I press F1 I enter the bios setup and if I press F2 it's boots fine after that and it seems to work normally. Still I'd like to know what the problem is and if I can fix it before it might get worse. I don't know anything about bios settings or anything like that so I could really use some expert advise. Already tried updating my bios, I have the latest bios version now but that didn't fix the booting problem.
Greetz 08Ray
Dec 31, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Recovery ****
this isnt a MAC so C wont help. click f12 then select CD ROM to boot from it. then it will ask "press any key" then do that. ....the rest figure it out yourself
Mar 10, 2009 | Toshiba Satellite A45-S120 Notebook
Laptop won't boot up.
http://www.cgsecurity.org/wiki/CmosPwd I have used this program at school to bypass bios passwords and i find it to work well.
You may also try to type Toshiba where it asks for the password.
Mar 10, 2009 | Toshiba Satellite A65-S126 Notebook
My acer 5100 laptop will not boot. I get a mesage "hard failure may be imminent, press F1 and continue" When I press F1 the cursor blinks at top left of screen and does nothing else.
I have one of these! also did you change your operating system? If not when it boots press F2 it will take you to the bios. In this you will see if your hard drive is being recognized. Let me know what happens and I will try to assist you further. Take care.
Be mucho blessed,
Mark
Aug 10, 2008 | Acer Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
