Question about Briggs Garden
Drain a vivaro fuel tank
Wrong fuel
2 Suggested Answers
  • 1162 Answers
SOURCE: Drain a fuel tank
On some cars there is a drain cock on the tank, if not on yours you just remove the fuel line an lit drain out from there. If you have a Chiltons or Haynes manual for your car it will show all these points for your car. Last resort call dealer or a local mechanic they can tell you right away.
Posted on Jan 29, 2015
I think someone put the wrong fuel in it and now its close to empty I've got to drain the tank on it and I don't even know where the draian is or should I just flip the damn thing over?
tipping the car over damages the paint work and will still not drain the tank better to disconnect the hose from the fuel pump and turn the car on
collect the fuel in a container
or you could just fill that tank with the right fuel and the contamination will be diluted right down to very little problem
pity you could not mention what the wrong fuel was as any petrol grade fuel ( all octane ratings including e-10 mix) will not damage a vehicle and if it was disilene for diesel engines then the mix will only cause it to smoke lightly if at all when mixed with a full tank of petrol
again you never mentioned the engine type so if it is a diesel engine then you have to get the petrol out of the tank by the method suggested
Apr 02, 2017 | Cars & Trucks
How do I drain the diesel from my tank put the wrong fuel in. Ssangyong sports ute
Check if there is a drain plug on the lowest part of the tank, if not can you pass a hose down the filler tube, if not remove the fuel gauge sender unit and use a hose to drain from there.
Sep 03, 2016 | SsangYong Cars & Trucks
After serviceing injector pump for opel vivaro CDTI 1.9 2003
NO START OPEL VIVARO FIX - YouTube
? 3:39
www.youtube.com/watch?v=i_G7Al9IFuU
Jan 21, 2014 - Uploaded by anto denn
All it does is crank but as soon as you fiddle with the injector ...Help have a 2003 trafic drove fine then one day i drove 100 yards and it just ... is the fuel pump turning on when you turn the key ?... Vauxhall Vivaro 2 0 CDTI Turbotune tuning box fitting guide - Duration: 6:40. by Darren Darling 28,094 views.
Sep 28, 2015 | Opel Cars & Trucks
Drain a fuel tank
Jan 29, 2015 | 2009 Saab 9-3
Starting problem.
You have replaced the fuel lines wrongly, the vacuum pipe and drain pipe are on the wrong way round, take the thin pipe off the tank drain, the straight down one, and put it on the angled fuel tap otlet, and put that one on the drain from the tank.
Jan 02, 2014 | 1998 Honda VTR 1000 F Firestorm
Wrong fuel in cherokee
Answer depends upon what "wrong fuel" you added. If it's a similar fuel
(gasoline but wrong grade etc) you can just keep using it and just use the right grade when you fill up. (same applies to diesel) But if you have used gas in a diesel or diesel in a gas vehicle, you have to drain the tank and purge the system to remove it. (tank needs to be taken down to drain). If you added under a quart of the wrong fuel, most times you can leave it alone and just fill the tank with the proper fuel and keep topping it off as you drive it to further dilute what was added.Your engine will usually tell you how unhappy it is with what you're feeding it.
Mar 05, 2013 | 2008 Jeep - GRAND CHEROKEE
I put the wrong fuel in the gas tank on a John Deere lt160.. Need to drain
Disconnect the pipe from the bottom of the tank or the inlet to the fuel pump and let it drain out, or use a tube to syphon the fuel out.
Jul 10, 2011 | John Deere Garden
Where's my fuel filter located in my vauxhall vivaro
opel vivaro ,its a belly tank and its mounted amidships ,about time they dropped the vauxhall and the holden names ,havent got a 1960s rust bucket cresta laying around in the garage have you ?? or a MkIV zodiac executive ,swop for a 1956 morris oxford ???
Feb 15, 2011 | Volkswagen Tiguan Cars & Trucks
By accident put the wrong fuel in tank
what do you mean by wrong fuel? if it's not diesel fuel then you may be ok
Feb 25, 2010 | 2000 Chevrolet Blazer
Put wrong fuel in tank
you have to actually drop the tank... drain out all the fuel and perhaps even clean the inside with a pressure washer... make sure it is completely dry before you assemble it again.... add a bottle or two of gas line antifreeze (it sucks up any remaining water) when you refill it and you should be good to go
Mar 23, 2009 | Peugeot 405 Cars & Trucks
Garden Logo
179 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
