Question about Sanyo Televison & Video
Tv picture cut off
Automatic cutt off fuse in tv supply . what is soulation ?
    Top Expert:
  • Sanyo Master
  • 74,482 Answers
If the fuse used do not match with its rating [low amp rated fuse] this type of fault can occur. If the used fuse is of correct rating, and still it blow up during working, the main board to your TV should be checked for short circuted component/s. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Mar 31, 2014
Sanyo tv cuts on then right back off
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_2_17_54_pm.jpgbad caps that are puffed up on top..
Apr 10, 2012 | Sanyo Televison & Video
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
Tv turns on and turns off after 5 seconds
jim if know how to soldering iron ,resolder your tv especially the power supply
Jan 26, 2009 | Televison & Video
My electric dryer will turn on but once it get hot after 3 minute
What cuts off automatically? Stops heating , or the drum stops turning?
Please reply your findings and we can help you further.
Jan 16, 2009 | Whirlpool LER5636P Electric Dryer
TV has sound but no picture
It is possible one of the internal fuses blew out.
It could be a bad horizontal outut transistor.
It could be a bad secondary of the power supply went bad
And many other things.
If it's just a fuse, it won't cost much, but a lot of them do not look like you would expect a fuse to look like.It might be a little yellow, green, or gray rectangualar box shaped part. :D
Dec 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Power cuts off for acer aspire 5100
I,d suspect your problem will lie with, the systems CPU ( Processor ) or a component Overheating on the systems Motherboard. I would,nt suspect the Power Supply personally. unless your batterys not charging.
Mike @ compurepair.
Apr 22, 2008 | Acer Aspire 5100 Notebook
No power no sound
oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Feb 05, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
