Samsung RM255LASH Side by Side Refrigerator
Problem for Samsung RM255LASH Side by Side Refrigerator
Fridge is not cold
By jennyly01 on Jun 15, 2009
the fridge temp for the samsung side by side fridge rose to 16 degree celcius making the fridge not cold.
Solution #1
posted on Jun 15, 2009
Somewhat Helpful)
CKsystems
Rank: Master
Rating: 81%, 8 votes
Side by side cooling units usually have 2 compressors, one for the freezer and one for the refrigerator. The refrigerator compressor may be bad, or not pulling enough power, or there may have been a leak in the tubing that the compressor uses to cool the unit with. To diagnose the problem, be aware of the noises the unit makes, and check to make sure it is a 2 compressor unit. If you only hear one compressor running then your compressor is bad, if you hear one running too often, then your tubing is bad, if the back of the refrigerator side is warm but the inside is not cooling down, then the compressor is not drawing enough power. Keep in mind that the radiant heat from the operational (presumably) freezer side may cause the refrigerator side to appear warm. (usually there is a type of wire backing with tubes running along it, these tubes should be mildly warm.)
Was this helpful?
Yes
No
Popular Solutions for Samsung RM255LASH Side by Side
Questions and Unsolved Problems for Samsung RM255LASH Side by Side
Do you recommend Samsung RM255LASH Side by Side Refrigerator?
Answer
Answer
I change my water filter, and when I try to reset the change filter indicator light on the front... (More)
Answer
Lost power to the house but when power came back on, the control panel flashes with 98 on the left... (More)
Answer
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is... (More)
Answer
Samsung RM25 Refrigerator. Display flashing 88 88 to 98 99. The second 99 is actually reversed.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung RM255LASH Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
