Sim lock and Network lock are same. Instead of resetting your Sim lock you can unlock your mobile using unlock code to remove the Sim lock. Get the code from the site Mobile-Unlocker.com ,and unlock it using unlocking instructions wh9ich is given in the sit itself.
The phone is not any network but still there is a sim lock with unknown password and no other sim card can not be used hard reseting codes default password are not working plz help
#7465625*228# = Activa lock OFF Type *#9998*627837793# Go to the 'my parameters' and there you will find
new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then
type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then
the green call batton and it's unlocked to all networks. This code may
not work on the older phones and some of the newer phones. If it doesn't
work you will have to reset your phone without a sim in it by typing
*#2767*2878# or *#9998*3855# (not tested)
It may not work in all phones, but with standard its working ;)
It Locked to security code or password lock? You can get the master reset code and reset the phone from security lock...It locked to network means use the network unlock code to Unlock the Sim Network lock,Specify the Model and brand? You can get the Network Unlock code and Master reset code at here Unlocking4free.com and Unlock it or reset it...You can try default code as 0000 or 1234 for Nokia to unlock from security lock ,if not works get the master reset code and reset it.
did u try this one * 2 7 6 7 * 3 8 5 5 # it removes simlock but with all the pictures n music u had on the cell along with phonebook contacts saved on the phone
