When i start up samsung LA40A550P1F
Delay in start up bot with remote and manually
What setting do you use for time delay on a Samsung NX 10, please?
Press MENU, select the camera-2 icon then select Drive. Select Timer then press Fn. Select the delay by rotating the dial or pressing left/right-arrow. Start the timer by pressing the shutter release button.
Full details are on page 54 of the manual.
Oct 19, 2012 | Samsung NX10 Digital Camera
My remote has a long delay on the up and down volume.it just started a few weeks ago and im getting annoyed..Common problem?
Manually turn the volume knob on the receiver several times as to loosen it up. Change the batteries.
Feb 25, 2011 | Onkyo RC-375DV Remote Control
Necesito programar mi control de alarma 5BCR07 y no tengo manual , envienme informacion les estare agaradecido
La ignición en, la prensa y la liberación que programan interruptor tres veces, oirá un gorjeo (channel1), botón de cerradura de prensa en el telemando, la prensa y la liberación cambian 1 tiempo (dos gorjeos, el canal 2) prensa desatranca botón, aprieta y suelta interruptor 1 tiempo (3 gorjeos), la prensa botón de comienzo, la prensa y la liberación remoto verde cambian 1 tiempo (4 gorjeos), botón de opción de prensa. Apague ignición, la prueba. Después de apretar los correspondientes botones en el telemando que programa sucesión arriba, debe oír gorjeos que confirma de la alarma.
Jan 20, 2011 | 5BCR07P Remote Replacement Transmitter for...
We have a Samsung SCX-4521F All-in-one which has
Good Day Sir, You can troubleshoot your machine by using service manual including Fax problems. click the link below to download your manual.
Manual
Good Luck and God bless.
Jun 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Auto delay on splits
All Split ac units have a safety system in them for a smooth switch over.
The delay time is different in all units especialy if they are "Inverters" or "soft start"
To be extra safe , just select prefered Temp and then Put it all on Auto.
Also some models have an anti tamper lock on the remote settings.
Feb 02, 2010 | Heating & Cooling
Samsung TV model CT 5029V - Lost remote control - AIR/CATV
do you have a menu button on the t.v. itself? if so gain access there
Nov 01, 2009 | Samsung TV Remote Control
When I start up my Samsung 52 it has a VERY long delay
Are you retarded? remote batteries? Sounds like your power supply is toast.
Jul 30, 2009 | Samsung LN52B750 52 in. LCD TV
REPROGRAMMING HELP
go into the simon, 64321 tech code then delete and the sensor button until it tell you which one you are on and then hit done..that deletes then to ad back depending on which sensor you are using , by hitting add then sensor and going to the room or door or what ever till you find the room and here is a list of all the setting for sensors smoke 26, d/w 13 no delay 10 delay, motion, 20 delay 17 no delay depending, shocks 13 on windows always 13, glass break 14, carbon 26, keyfob 01 there are more but these are most common
Dec 30, 2007 | GE Security Simon 3 Wireless Home Security...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
