The dehumiifer on the furnace is laking. water is cming out alot just wanted to know what to do to stop the water because it is one big mess
It is a Honeywell Dehumidifier
    Problem Solver:
  • 14 Answers
Use spell check.
Posted on Apr 05, 2014
Oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
Tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 | Heating & Cooling
My trailer furnace is a coleman DGAA. everything seems to be running good except cool air is cming through vents. takes a long time to get my olace warm.
1 of 2 things, 1, check calibration to match control amperage, 2, check fan switch, but if you have ever changed the thermostat it more then likely your calibration. GARRANTEED
Dec 30, 2010 | Coleman Heating & Cooling
I have a lake house with irrigation system drawing water from the lake. The pump works. But there is a second primer pump that I do not know how to turn it on or how it supposed to work.
I used to take care of a system like that in the basement of a ten story college dorm. There was a big pump and a little pump. The purpose of the little pump is to maintain pressure when there is no usage of water. Then when a big demand comes, the big pump kicks in. I had problems with the
big pump getting hot, because the controls didn't work right. I unhooked all the controls and strapped a heat sensing aquastat box to the discharge pipe. When the water got hot, this state
would open a tiny little solinoid valve and dump enough water down the floor drain to keep the
pump cool.
Nov 04, 2010 | Plumbing
Pump making a grinding noise, would this stop boiler igniting?
maybe yes if there is a switch in the pump that stops the furnace if it does not pump..., but you will also have a mess soon when the pump quits and water goes all over the floor....
Sep 06, 2010 | Heating & Cooling
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Need to know how much water to put in
Hello. You can empty it by taking it to a sink, first unplug it, and tip it toward the end it brews from until the water stops coming out, not too much at once, as the pipe is only so big, so go easy or you'll have a mess. Then after doing whatever it is, before plugging in, just pour water into it until it come out of the brew head, then you know it is full again, and can now plug it back in. If you need more information, as there are several Bunnomatic models, and you did not include yours, you can go to www.bunnomatic.com, and get a owners, or parts manual.
Hope that helped, and thank you.
Mar 18, 2009 | Coffee Makers & Espresso Machines
I just hooked up a honneywell whole house humidifer in my 1000 sq ft home. (last week) . i now see that the humidy has been at normal living condition. my problem now is i see i sttill go thru 15-20 gals...
Thanks for your question,
Well thats the big problem with bypass Humidifiers, they use alot of water, is yours running all the time, even when the furnace is shut down ? if it is, its wired in wrong, if not then there is not much of a solution for ya, is the humidity level in the home comfortable to where you can actually turn the house t-stat down ? if not you may want to incress the amount of humidity to be able to turn your house t-stat down, you should be feeling about 3 to 7 degrees warmer with the right amount of humidity, sorry I couldnt be more help, but thats the nature of that unit, just a little FYI, if you ever decide to try something different, may cost a bit more, try a steam humidifier, alot less water usage, its filtered, and pretty reliable too, thanks again for your question, hope atleast part of this helped !
mr.grzz
Jan 05, 2009 | Honeywell HE220A1019 Whole House...
Water Tank Will Not Stop Running Water
the reason your water keeps running is because the float has not closed of the valve in the stem on the left side. a quick fix is i take the rod that has the float on it and bend it down a little. i also make sure that the plug that fits over the drain seats properly alot of times through age the plug tends to harden up and not seat properly. if you cant get it to seat replace it. if your model has an adjustment screw on the valve body try adjusting that as well.......good luck please rate this
Sep 01, 2008 | American Standard Colony 2388.012.222...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
