Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
Battery charger 12v bec1263c
My 12v charger is no good.
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Where can I purchase a battery charger for the 12V Surfer Girl Pink Jeep
www.powerwheelsbattery.us
Look for:
NPL2 12V Charger Playmind FUMWZ0565-2020
$33.95
Jul 18, 2012 | Princess International Surfer Girl 12v...
Hello, Leoch 12V battery, DJW12-12Ah, is no longer charging. We bought a John Deere riding toy at a local Toys R Us in Michigan three years ago. My children have only used it for two summers and is...
Sounds like a battery problem.
Lead acid batteries should to be charged every 3 or 4 months even if they are not being used, or they can slowly self-discharge and will start to deteriorate if the voltage drops below about 12.2v (for a 12v batt.)
They can then be difficult or impossible to charge. The charger can see this as fully charged and show green.
You can test for this if you have a voltmeter. You should be able to work out if it's the battery or a connection (or the charger).
Measure the battery voltage (use a DC voltage range greater than 12V). The normal voltages you should see:
A) Key off, no charger: >12v, <14
B) Key off, charger connected: >12, <14.2, but higher than A)
C) Key on, no charger: >12, <14, but lower than A)
If voltage A) is low and immediately goes high when the charger is connected then the battery needs replacing.
If A) and B) are exactly the same then it could be the charger is not connecting or is faulty. Measure the charger output, should be >13.8v (unless it's an "intelligent" charger in which case it might need some voltage applied to its output before it starts charging).
Note: If A) and B) are low, say <8v it's possible that an "intelligent" charger will refuse to start charging. In this case it's probably worth jumping the battery to a good 12v battery (e.g. car). Be very careful to connect the batteries (+) to (+) and (-) to (-). Leave connected for 10 - 20min or even overnight and then disconnect jumper leads and check A) and B) again. Sometimes a battery can be recovered by this method (it's unlikely to regain full capacity though).
Jul 19, 2017 | Lee-t.com Facebook Apps
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
How to tell if battery is full charged before using it.
The easiest and best way to test any battery is with a volt-meter.
http://www.northerntool.com/shop/tools/product_12496_12496
The link above is for a multi-meter. These are inexpensive and are an extremely useful tool to have. For about $15-20 you can buy a meter which will test AC/DV voltage, resistance/continuity and often diodes and/or transistors as well.
A fully-charged 12v battery will give a reading of 12v (or very close to 12v) on a volt-meter when it is fully-charged. 6v batteries should read 6v, 1.5v batteries should read 1.5v, etc, etc.
If the reading is lower than the power output of the battery, the battery is either not fully-charged or one or more cells may be damaged. If cells are damaged, you will never get the full 12v output from a 12v battery.
There are other ways to test batteries but they are less accurate. It's possible to use a battery charger, but you can only use this to determine whether a battery is fully-charged if the battery is known to be good. A fully-charged battery should draw 0 amps on a battery charger, but a damaged battery may also draw 0 amps so this is not a good test.
Basically, I'd suggest you get yourself a multi-meter. You be glad you did!
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Mar 11, 2011 | 300 Amp Battery Jumper with Air Compressor...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
Batterys dont keep there charge i think the batterys need to be replaced
before you dump those batteries, check the charger. If the battery when charged runs the tool but dies out quickly then you are probably right. If the battery never seems to be charged at all, then it may be the charger.
Dec 10, 2009 | Hitachi DS14DVF3 14.4 Volt Ni Cad 3/8 Inch...
Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Nov 10, 2009 | Bosch Drills
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
73 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
