Question about HP Photosmart C6180 All-In-One InkJet Printer
I have a HP photosmart C6180 with Oxc19a0024
It will not print, and says that the ink system has failed. I have tried several fixes, including one recommended on Fixya, but nothing works. Any help is appreciated.
Add andydragoescu on your y mess and y will try to help you!
Posted on Jun 15, 2009
Ink system failed???unable to print,copy,recieve faxes
Hello
Have a look at the link below, it should assist you in solving your problem.
http://h30434.www3.hp.com/t5/Other-printing-questions/Ink-system-failed-Error-Oxc18a0101-on-photosmart-D7160/m-p/14911
Nov 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
I use a HP photosmart all in one printer 6100 and i have an error message "ink system has failed" I am unable to print, copy of fax
Several HP all in one owners have had similar problems. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to your HP 6100 printer. acca299.jpg
Oct 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 All-in-One printer that is 3 years old. It has been a great printer for our home. Today it decided it would no longer print and I get the following message: Ink System...
I had an ink system error message on my C6180 that evolved into the printer power cycling every 15 seconds of so. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Aug 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP photosmart c6180 all in one printer error message of 0xc19a0035, ink system has failed. unable to copy, receive faxes, or print. what can i do to fix it?
The "Ink System Failure" error is caused by air in the ink fed tubes. We have a step by step guide to perform a ink purge on the printer posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Following this procedure should get your printer back running in about 10 minutes.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
My hp photosmart c6180 prints green photos on photo paper. it prints fine on regular paper. all my ink cartridges are hp and new. how can i fix this. i have tried several different types of photo paper as...
Check to make sure all of your contacts are clean. The part where the cartridge meets the printer. Also check to make sure you have it set in the printer properties for photo quality paper. If this still doesn't work, I would suggest trying a different brand of paper, it may be the problem with the paper manufacturer.
Oct 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 all in one the error message displayed is ink system has failed it will not print appreciate any help
The Ink System Failure messages on my C6180 were early symptoms that progressed continuous power cycling. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these. here is a .
Jun 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system has failed
Solution
Wait two minutes.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
273 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
