Question about KitchenAid A-9 Electric Burr Grinder
Reach/remove pin. This post/shaft is too tall to be able to reach, remove existing broken pin and replace. This KitchenAid A-9 is KCG200WH1. Should I take the bottom of the machine off, then will it pull out from below? Frustrating. I have seen pictures of the pin as it should be, but the shaft doesn't look as tall as mine. Both burrs are out. The top burr has a part, looks like a black umbrella. Today the mill is running really well, beautiful grounds that look like ground coffee from a can. However, I can disassemble again, take a picture. I figure it will soon start spraying grounds and screaming if I don't replace that pin. Thanks.
  • 1 more comment
  • Patricia
    Patricia Apr 07, 2014
    Thanks for all feedback. As it turns out, this model needed a little extra work. I removed the shaft assembly from the bottom, replaced the broken pin and it's more noisy then before, but grinding like a champ. The nut under the bottom burr is not tight but it's clean and working well. It was suggested that I apply "food grease." After spending 8.00, and not knowing exactly where to put it, I don't see a difference.
  • Patricia
  • Patricia
    Sorry about repeat, don't know how to delete it. Important to know model KCG200WH1, as different. Also, I am left with a small silver, pretty washer that came out from somewhere. It's too pretty to be from the inside, so I'm assuming it belongs around the toggle switch. I'm not going to mess with that as I will not remove the bottom again. That switch tends to go sideways, rather than up and down if not exact. Done.
  • 4 Answers
Patricia, I am not sure which model you have old or new. I have the old one built in the 30's. I had to replace the shear pin and the carbon brushes for the motor. I took the bottom off which has a ball bearing resting loosely in a cavity in the bottom plate. Don't lose it. Now the brushes I found at an ace hardware. Take the old ones to compare. I think there was a bracket holding the brushes and rotor in. Once the rotor was out you could get the brushes out. Putting the brushes in required figuring out how to keep the brushes retracted. I used a piece of paper and used it hold them back while sliding in the rotor. Once in pull the paper out.
Now the shear pin needs to be in to prevent damage to the grinder in case what you are grinding has something too hard to grind like a small rock, I think if you push up on the rotor when the bottom plate is off or pulling up on the shaft it might give enough clearance to put the shear pin in. It sits very close to the bottom of the shaft so it can be fun trying to line it up. I used needle nose pliers to hold the pin just right while pulling up on the shaft. I bought the shear pin off of ebay
Posted on Mar 31, 2014
  • Patricia
    Patricia Mar 31, 2014
    Thank you, I'm keeping all these notes. I have 2 mills and the 2003 bought new is perfect. The other, circa 2006 is the one with broken pin. It's crazy because it's so near the bottom of the shaft to get at. I any event, is working so well with half a pin, I'm going to grind up all that is in the jar before I proceed. The folks who sell the pins on eBay are trying to help. I'm sending a picture once I stock up on ground breakfast beans. I'll post when I get this thing figured out, and I will.
  • iar823pilot Apr 07, 2014
    The sounding worse isn't good but they do make some noise but if it sounds like metal contact then a little more work might be in order. On my 1930/40s model It was making those scrapping screeching sounds and I found the carbon brushes for the rotor in the motor had been worn down until they were basically square blocks instead of the longer length normal new brushes are. What was happening was the brushes would cant a little so only a part of it was making contact and causing the scrappy squeal. New brushes and normal grinding noises. Another possibility is the grinding teeth are barely touching during the grind for which you have to adjust the distance between the grinding wheels. Hope this helps;.
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Tip
How to troubleshoot a system that boots up but wont display
  • VGA cable replacement
  • Needle-nose pliers
  1. Power downthe computer. Check the VGA cable running from the computer to the monitor. If the cable is not snugly seated in both ports, the video signal will not reach the monitor.
  2. Check the connector on each end of the VGA cable. Examine the nine pins on each connector. If any of the pins are bent or broken, the video signal will not reach the monitor. If there are just a few bent pins, you maybe able to straighten them with a pair of needle-nose pliers. Be careful not to break off any of the pins. If any of the pins are broke nor missing, you will need to replace the VGA cable with a new one.
  3. Disconnect all cables and peripherals from the computer. Open the computer case by removing the Phillips screws along the side or back of the case. Remove the cover or side panel to expose the internal components. Locate the VGA card and make sure it is fully inserted into the PCI card slot. If the card is not installed correctly, the video signal will not reach the monitor.
  4. Close the case, reconnect the power cord and all cables, and power up the computer. The video signal should display on your monitor.
on Jan 17, 2011 | Computers & Internet
KCG200WH1 model
If you mean a chrome with serrated edges then that is a screw type ring that screws on the toggle switch on the outside to hold the switch tight in place against the body of the grinder. Place the ring over the toggle and hold the switch in place and screw the little ring on until tight.
Apr 07, 2014 | KitchenAid A-9 Electric Burr Grinder
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
KUDR24SE hinge springs have broken, how do I get in to replace them?
You have to remove the screws holding it to the counter top and slide the dishwasher out about 1 foot and you'll be able to reach the springs at the bottom on each side.
Mar 07, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
I lost my keys and i need to know how to replace my key cylinder on my 1993 mercury cougar xr7. I have a new one.
remove screws from steering colum and remove cover,
you will need a drill, needle nose plyers and a very small screw driver phillips.
step one. drill 1" into cylinder.
located on bottom of colum is a small hole with a pin in it.
step 2, push pin up, if it does not move drill 1/2" more in to cylinder.
stop if you reach a small shaft that is kinda loose and has a brass washer or steel washer on the outside of it. remove small shaft with plyers. once the cylinder is drilled it should unlock, turn it and push the pin up untill it comes out
May 16, 2009 | 1993 Mercury Cougar
How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
Mar 10, 2008 | KitchenAid KAWS750L Top Load Washer
Need to replace drive pin
Hi. The pin in question is a tapered pin and can only be tapped out one way. This pin fixes the main driving shaft to the planetary. Use a metal punch slightly smaller in size to the pin and gently tap out the remaining part of the pin toward the largest part of the pin. Once removed, you can install the new pin in the reverse manner. If this solution assisted you, please rate it. Good luck! ricardok45.
Jan 11, 2008 | KitchenAid KSM50PR Professional Series...
KitchenAid A-9 Electric Burr Grinder Logo
269 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
