Question about Plumbing
We have Atlas copco XA 137 dd model and the compressor oil leak/mix hugely with the delivery air.kindly please advise what might be the reason.
    Genius:
  • 1,114 Answers
I'm not familiar with this compressor per say , but if the compressor is a piston compressor, it may be over-filled with oil or there may be blow-by of oil past the piston rings, as in a car that blows oil past the rings. There should be a way to test for compression and if the rings are leaking.
Posted on Apr 06, 2014
Compressor motor converter failure for compressor GA315VSD
if it is this unit this link may help you
http://www.about-air-compressors.com/atlas-copco-compressors.html
or try this one you tube link
https://www.youtube.com/watch?v=QUj-mrzxS4o&ab_channel=ChouseMolla-Storm
How to reset Atlas Copco Electric Air Compressor
Sep 17, 2017 | Air Tools & Compressors
I have a atlas copco compressor 185 after I change the separator it is blowing hot air and keeps turning off
The change may have stirred up the oil; and subsequently, a piece of dirt or sludge is lodged in thermostatic mixing valve or separator scavenge line. Because it is sounds like it is shutting down on high heat, I would look at the mixing valve first.
Jan 14, 2015 | Air Tools & Compressors
Where do I get a spare parts manual for a Atlas Copco xas 160
The staff at www.aircompressordelmarva.com has all the manuals for atlas copco air compressors. You can email or call them. They posted an Adobe link for me for a really large one so I could download it. Very helpful. Delmarva Air Compressor Powered by Network Solutions
Nov 15, 2014 | Air Tools & Compressors
I have air compressor atlas copco GA 75 after i change the oil separator AT (8500HR) with 135hr was damage . i review all connection but i didn't reach the reason for this problem
possible cause is that minnim pressure imploded the separator due suddenly opening the valve on the discharge of the compressor so all internal pressure get released to quick and that what causes the separator to fail
Oct 29, 2014 | Air Tools & Compressors
Have a GA7ff Atlascopco Screw Compressor. Discharge of oil from Intake & went out on heat overload.
Sounds like a bad oil seal. If the oil level is too low, it will overheat.
Jun 02, 2012 | Air Tools & Compressors
We are using three screw oil free atlas copco compressors{ZR-275}. They often encounters the problem of high outlet temperature of first stage , almost near tripping stage. and we have to replace the...
Dear Hamza,
High Temperature at First Stage means your Second stage is becoming Weak and it is not capable to pull the maximum air from First stage, If it is only at loaded position.
If this is your regular problem you must check your Water condition it should not be below 20 degree C and not above 40 degree C.
You may also try to blow some dry air into second stage ( HP Element ) when ever it is in off position.
Hope this will help you.
Regards
Ashfaq
May 21, 2010 | Atlas Translator Atlas Copco Air Hammer...
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Plumbing Logo
112 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
