Question about Master 1500ID Combination Padlock
I forgot my code for my master speed dial lock and I reset the lock and i accidentally forgot my code
I can't get my lock combination right and I am frustrated about getting the lock to open could you please help me to open my lock combination it would help a lot
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    How to reset combination
    To set a new combination:
    The initial combination is set at the
    factory to 0-0-0-0
    1. Open the compartment door
    2. Push the reset lever left and down.
    The lever remains in this position
    3. Rotate dials to your desired combination
    4. Push the reset lever, up and right, back
    to the original position
    5. Close the key storage compartment door
    6. Scramble the combination dials to lock
    the door and conceal your combination
    7. Close the shutter door
    Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
    I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
    1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
    2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
    Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
    I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
    Try 2 options:
    1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
    2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
    Ity
    Sep 06, 2011 | Office Equipment & Supplies
    I got the master lock speed dial and forgot my combination
    Try your old password but push the shackle towards the lock once then put in your old password twice then pull the shackle
    Sep 16, 2009 | Master Lock 5400d: Portable Select Access...
    Get the numbers master dial combination lock
    Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
    Please rate. Thanks
    Feb 21, 2009 | Hardware & Accessories
    I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
    Instructions:
    Opening the key storage
    compartment door
    1. Open shutter door to reveal the dials
    and the release button
    2. Rotate dials to the current combination
    (if the lock is new, the combination is set
    at the factory to 0-0-0-0)
    3. Press down on the release button
    to open the door
    4. Pull the door fully open
    5. Add or remove keys
    6. Close compartment door
    7. Scramble the combination dials to lock
    the door and conceal your combination (A)
    8. Close the shutter door (B)
    factory to 0-0-0-0
    (see instructions above)
    7. Close the shutter door (B)
    To hang shackle model
    2. Push the shackle release lever to the left
    to open shackle
    3. Pull the shackle up and out of the lock
    4. Place shackle around door knob or other object
    5. Close shackle to lock
    6. Close the compartment door
    Reminder:
    (A) The release button will open the lock
    until you scramble the dials
    (B) Keep the shutter door closed to increase
    weather resistance and to conceal the
    dials from view
    Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
    Master 1500ID Combination Padlock Logo
    66 people viewed this question
    Top Master Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Master Lock and Locksmithing Expert? Answer questions, earn points and help others
