Question about Samsung N145-JP01US Netbook
N145plus reset store
Reset point
Needpasswordbios for asamsung n145plus tabletNeed
There is no way easily figure out a personnel password, if there was what use would having one be. In order to bypass this lost password you must do a factory reset.
Jan 20, 2017 | Televison & Video
I got a 2001 point grandprix the security light keep flashing it starts up and dies i reset it but it does the same thing
Reset what ? How ? Light flashing , there is a DTC - diagnostic trouble code stored in the Computer system pointing to what the problem is ! You need to have codes pull to see where to start diagnostic's !
Dec 04, 2016 | Cars & Trucks
Have a samsung notepad n145plus locked in logging off for 24 hours
You're going to have to take out the battery or hold down the power button in this case, you're having a shut down failure and sometimes these things happens.
You might want to get your computer checked up on soon, cleaned out, de-dusted and such.
I hope this helps, I'm sorry buddy.
Feb 25, 2013 | Computers & Internet
How to factory reset
An operating system ? and make of computer ? would be nice to know so someone could give a precise solution.
Reset your desktop computer to make your operating system work better. Reset a desktop computer to its defaults to override unwanted changes. Reset your desktop computer settings to the browser default settings to ensure safe use of the Internet. Always try to resolve your computing troubles by resetting your desktop computer.
Use your desktop computer's recovery system to a time when the system was working better. To reset your desktop computer to a store point, left-click the "Start" menu, point to "All Programs," and "Accessories," and then "System Tools." Click on "System Restore." Click on the option to "Restore," then click the "Next" button. Click "OK." You may also use the feature to "Set Restore Point" for future needs. In the next step you will clean up your file paths and file space to ensure that your computer is running the operating system smoothly. Click on the "Start" menu. Point to "All Programs." Point to "Accessories." Point to "System Tools." Click on "Disk Defragmenter." Click on the "Defragment" button. Close the Defragment program. Your computer will run like new. It is a good idea to restart your computer. Close all programs, then click on the "Start" button. Click "Turn Off Computer." Select "Restart." Click "OK." b> Reset a PC for the Manufacturer, Microsoft, or Non-Microsoft Program Defaults b> Click the "Start" button. Point to "All programs." Click on "Set Program Access and Defaults." Click on "Computer Manufacturer" to reset your desktop computer to the manufacturer's settings. Click on "Microsoft Windows" to reset your Internet Explorer and MSN Messenger settings. Click on "Non-Microsoft" to reset Mozilla Firefox settings. Click "OK." Your browser, email, and instant messenger settings will now be reset to the manufacturer's specifications.
Dec 30, 2012 | Computers & Internet
What parts do i need to connect the n145plus netbook to wifi
If your netbook came with a wireless adapter already installed then you should be good to go. If it has a wired connection for the internet (looks like a phone cord but a little larger) and no wireless adapter then you will have to purchase one. You can buy a wireless adapter that plugs into your USB port from any pc store. If you are going to buy a wireless adapter to connect to wifi make sure you install the software for the adapter first before connecting it to your pc or it might not recognize it.
Oct 09, 2011 | Sylvania G-Netbook
I have the same problem with the same model. How to reset , Sir ?
To reset the Walkman Player, press the RESET button located near the Strap hole using a sharp pointed object like ball point pen etc. When you turn on the Player after resetting, the Player reactivates the previously set items.
Make sure that you're not resetting the Player while operating the Player, as this may delete the stored files and settings.
Thanks for using FixYa.
Feb 28, 2011 | Sony NWZB133F MP3 Player
I have a radio shack hyperscan 200 channel pro-2039 programmable scanner. How do I erase ALL the stored frequencies so I can start over again?
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Oct 05, 2010 | Radio Shack Radio Communications
BRAKE LIGHT ANS ABS LIGHT SERCIVE HOW TO RESET IT
need to have scanned to fix the problem some auto stores such as auto barn / advanced auto scan for free the trouble code will give u a start point towards fixing ur problem-- reset when problem fixed or have auto store reset after scan but will most likely return
Jan 31, 2010 | 2001 BMW 325
Ecb-8610 reset itself
It could the the hold and store capacitor going bad. This would cause the flash memory to corrupt and drop back to a default configuration.
Sep 10, 2007 | EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g...
Samsung N145-JP01US Netbook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
