Question about Clear-Com CC-95 Headset
I have a Clear Com CC-95 headset and I want to disable the speaker. Reason: I want to place it backstage with the Mic open for one-way monitoring. It is no longer used because the headband is broken, but turning it into a mic-only unit will be very useful to me. So, my question is: Which wires send sound inputs to the earpiece?
    Scholar:
  • 95 Answers
Ok if yo wanna disable you internal speakers.
If you're running Microsoft Windows you can disable the Internal speaker or PC speaker by following the below steps.
  1. Open Device Manager
  2. In Device Manager click View and click "Show hidden devices"
  3. This should make "Non-Plug and Play Drivers" visible in Device Manager.
  4. Expand Non-Plug and Play Drivers by clicking the plus and double-click Beep.
  5. Within the "Beep properties" window click the Driver tab.
  6. Under the driver tab if you wish to temporarily disable this device click the Stop button. If you wish to permanently disable this device under the Startup Type select Disabled.
EXTERNAL SPLITTING:
when its connected to the external devices like DJ-turn table,mastering amplifiers boards,if yo wanna use only only the mic for backstage.
just disconnect the mic from the damaged headphones(use anthing this to split but tak concern of the wire not to be damaged) and you will be getting a wire along when you disconnect,so get that wire along don ever touch that,apart from that you will have the wires run to your headphones,just cut that and wound it with the cellophone tape,make them not to touch each other while playing,because you will get some loss.
Posted on Jun 15, 2009
Cc-40 headset microphone will not work
The mic element has probably gone bad. You can verify this with a multimeter, measuring between pins 1 and 2 you should see either infinity or 50-400 ohms depending on the element. If you get open circuit that is confirmation the mic element is bad.
Feb 13, 2014 | Clear-Com Radio Communications
Cant get the mic to work
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Dec 21, 2010 | Gear Head WC330I Webcam
On to my second web cam, tried logitech and now microsoft life cam 3.0, no problem with video but can not get any audio!!
XP
VISTA
TEST SPEAKERS
Restart computer
Dec 10, 2010 | Microsoft LifeCam VX-3000 Web Camera
My microphone on my quickcam is not working it say its in use but its not
XP
VISTA
TEST SPEAKERS
Restart computer
Dec 03, 2010 | Logitech QuickCam Communicate Deluxe...
Cant adjust microphone
Make sure your webcam mic is set as default
XP
VISTA
TEST SPEAKERS
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
Sep 05, 2010 | Logitech Webcam
I can't seem to get my microphone to work. Every other sound is working.
You do not say what sort of mic you have - if its a built in laptop mic, a standalone mic or one built into the webcam.
It would also be useful to know what your OS is and what chat program you want to use the mic in
However we can generalise and hopefully put you on the right track
XP
VISTA
TEST SPEAKERS
Restart computer
Configure your webcam and mic to the Chat program
Aug 31, 2010 | Logitech Webcam
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
VISTA
TEST SPEAKERS
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
People at the other end can not hear my voice i can hear them
XP
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
VISTA
TEST SPEAKERS
Restart computer
Aug 25, 2010 | Logitech QuickCam Connect Webcam
My speaker stopped working after some time!
may be problem in lose wire connection ,
check that first.
may be there is a problem in mic from where u talk,
open the mic cover smoothly,check all the wires are joint if not join it properlt,
still problem take off ur mic and check with speaker or with other equpiment like ur mobile headset,if mic is ok then put back, if not do *
join wires again properly,next
open joiner where the speaker and mic are joined,may be there are some wire disconnection join it ,if properly joined,
* then there is a problem in mic
replace the mic with same type of mie or u can use the mic of ur mobile head set or find it someware ,
join it ploperly.
it works.
goodluck
email rushi_jky@yahoo.com
Apr 28, 2010 | Cyber Acoustics AC401 Consumer Headset
VX-3000 microphone still enabled with headset. Is
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower drop-box display "Use this device enable" click OK
Restart computer
Dec 31, 2009 | Microsoft LifeCam VX-3000 Web Camera
Clear-Com CC-95 Headset Logo
52 people viewed this question
Top Clear-Com Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Clear-Com Radio Communication Expert? Answer questions, earn points and help others
