Question about OKI MICROLINE 5520 Matrix Printer
We have a print server and send prints via SAP.For example we send 70 pages and it prints 69 pages.We send 100 pages,it prints 99 pages.print server is windows 2008.However when we use a local laptop
Print server problem
  • Berk Uzel
    Berk Uzel Mar 31, 2014
    when we use a local laptop,no problem
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Just reset it
Posted on Mar 31, 2014
Soulvisitor
  • 1113 Answers
SOURCE: OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Posted on Jan 05, 2008
Sphynkter
  • 221 Answers
SOURCE: Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
I just had this exact same problem - same printer, same Jetdirect model. Mine turned out to be the parallel printer mode setting inside the JetDirect. I connected to the configuraiton page by IP, then changed the Parallel mode from "AUTO" to "Centronics", tested it, and it worked fine after that. Hope it helps.
Posted on May 11, 2009
  • 44 Answers
SOURCE: Cannot print on the network
I would print out a menu map from the printer and check the IP address that is set is the same as the one in the ports tab in the printer properties. If this is not the case then change one to match the other. Also make sure that the printers IP address is set manually and not by DHCP because DHCP will change the address every time it is switched on/off.
Posted on May 12, 2009
duane_wong
  • 6826 Answers
SOURCE: printer laser b410 print empty page
I would uninstall and reinstall the driver:
http://my.okidata.com/oki-faq.nsf/FAQCentral/77AE0D0F5AEA7EDD85257666004F56C7?OpenDocument
Posted on Jul 20, 2010
broyyce
  • 30 Answers
SOURCE: I've been using OKIDATE MICROLINE
You would have to cancel the current print job from your computer for it to stop. Assuming you have access to a computer that is connected to that printer, you will have to find that printer by going to Control Panel > Printers and Faxes > Oki ML 320 then right click, select "See What's Printing" and cancel Current print job (I am also assuming you are using windows). I really hope this helps, if not add a comment clarifying your question, thanks.
Posted on May 23, 2011
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
TRENDnet TE100-P11 shows print online but won't print
You have to create an LPR port for it to print successfully.
Download the User's Guide from the following link http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1316
and then follow the instructions from Page 22 to 24
Jun 24, 2010 | Trendware TRENDnet TE100-P11 Print Server...
Can't print in SAP R3 to HP LJ2600n
Supported HP Printer: HP Color LaserJet 2600n printer
(Host-Based)
Recommended PCL5 Device Type: SAPWIN
- requires Server-based printing via SAPSprint or Frontend Printing via SAPgui
Supported SAP Release: See SAP Note # 8928
Dec 11, 2009 | HP Color LaserJet 2600n Printer
TrendNet PrintServer TE100-P1P does not print
I get the same error connecting to an OfficeJet K60. Have been successful with my Macs, but not with XP.
Jul 08, 2009 | Parallel TRENDnet TE100-P1P 1 Port Print...
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Wingdings prints on Brother HL2170W
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
Feb 26, 2009 | Brother HL 5250DN Laser Printer
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
OKI MICROLINE 5520 Matrix Printer Logo
59 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
