Question about Optoma PCMD Projector Ceiling Mount for ES526
Menu ulock the es526dlp projection display optoma
Optoma key unlock
OPTOMA PROJECTOR hd25e LOCKED CENTRAL PANEL AND IR DISABLED HOW TO FIX
Your problem same like me,just hold on the ENTER button 7 second and than press the SOURCE button,the projector will auto reset.
Dec 17, 2014 | Optoma Office Equipment & Supplies
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
Full Desktop does not appear, video does not show.
You must tell the laptop to change display mode--there are 3...Normally, the key-press is something like "function key, F4"--look for a small tv screen symbol on one of the "F" keys--default mode is "laptop only", Press and hold "fn" and then press the appropriate "F" key, the laptop will switch to "laptop/external display". Another set of key presses will get "external display only" mode. And, finally, the next sequence will bring you back to the default mode. Make sure you turn on the computer and *then* turn on the projector to head off any sync probs.---Rick
Sep 21, 2009 | CTX Optoma EzPro 710 Multimedia Projector
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
Jul 07, 2009 | Televison & Video
The Buttons are locked on my DX625 DLP Projection Display
you'll need the remote to unlock them. go into the menu, settings, key lock, unlock. if the remote is lost or locked, too, you'll have to contact a service center.
May 11, 2009 | Office Equipment & Supplies
Help me please Optoma HD72 DLP
In the menu you can change the phase of the signal or the tracking. In Menu - Setup
Jul 05, 2008 | Optoma HD72 Multimedia Projector
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Optoma PCMD Projector Ceiling Mount for ES526 Logo
16 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
