Question about collect3 Beatwave
Not able to see beatwave menu
Not able to see menu for beatwave on ipad after saving some samples
Purchased second hand ipad cannot activate it because it needs activating with the previous owners icloud details , cannot get in touch
Put ipad back to default settings. Settings menu--This will erase everything on the iPad so you can start as a new user. It will erase original users saved info so you can input yours
Mar 07, 2015 | Apple iPad 4th generation
Tip
Play 1080P MKV movies on iPad 2
Do you have tons of MKV files, but yet have been never able to convert them into a proper video file for your new iPad 2 on Mac? If so, this article is deserved reading on, because it aims to tell you how to convert MKV to a playable format for iPad, so that you can enjoy your MKV movies on that wider display in high quality. <br /><br /><b>Required software: <br /><a href="http://wannasoft.com/Pavtube-Video-Converter-for-Mac/">MKV to iPad 2 Converter for Mac</a></b> <br /><br />Following is the detailed instruction of how to convert MKV to iPad and iPad Wi-Fi 3G accepted format, feel free to check it and get what you are looking for. <br /><br /><b>Step 1: Click "Add" button to load MKV files into this program</b> <img src="mkvmac-total-20100517.jpg" /> <br /><br /><br />This Mac MKV to iPad converter supports batch conversion, thus you can add multiple MKV files to it at a time. More than that, if you want to combine all the files into a single file, you should tick the checkbox "Merge into one file" to achieve this goal. <br /><br /><b>Step 2: Select output format for iPad/iPad 3G</b> <br /><br />Click on the pull down menu of "Format" firstly, and then you will see there are an "iPad" option, and three sub-presets optimized for iPad. You can select anyone of the three profiles to meet your requirement. All of them will guarantee you a perfect playback quality on your iPad and iPad Wi-Fi+3G. <img src="mkvmac-format-20100517.jpg" /> <br /><br /><br /><b>Step 3: Set advanced settings</b> <br /><br />Click "Settings"button, then the interface as below will show up, you are allowed to adjust video and audio parameters shown on it, including codec name, bit rate, image pixels, frame rate, sample rate, and audio channels. However, we suggest you to skip this step, because the default settings will absolutely ensure the excellent playback quality on your wide screen iPad. <img src="mkvmac-settings-20100517.jpg" /> <br /><br /><br /><b>Step 4: Start <a href="http://www.pavtube.com/mkv-converter-mac/">converting MKV files to iPad</a> and iPad Wi-Fi+3G supported format </b><br /><br />As soon as all the above three steps are finished, you can click "Convert" button to start converting MKV files to iPad compatible format. Once finished, you can click "Open" button to get the output files. Now just add these converted MKV files to your iTunes, and sync them to your iPad for watching. <br /><br /><b>For Win Users</b>: <a href="http://wannasoft.com/Pavtube-Video-Converter/">MKV to iPad 2 Converter</a>
on Mar 11, 2011 | Computers & Internet
Tip
How to convert wmv video to ipad
"iPad is here." We get the exciting news from Apple.com. iPad is amazing! Right? There is a trouble on iPad to my friend Jerry. How to transfer WMV video to iPad ? He can download the same video with the format that ipad can read from apple store directly. However, he does not want to pay for the video for that he has got.<br /><br />As we all know the iPad plays videos only a handful of video formats, none of which are overly common for standard sized videos (.mov, MPEG-4). Most torrents are AVI videos, and it would be easy to lose the HD quality of a Blue-Ray when converting to MP4 format or other accepted formats.<br /><br />It may not sound easy, but it's actually very simple to convert WMV video into a format compatible with your iPad. Thankfully there are great people out there who write free software to do all of this for us! Here I recommend one video to ipad converter software , which can help you to convert WMV video to ipad accepted format. If you do not know how to do that , just following the next simple steps.<br /><br />Step 1: Free trial is available and safe. So you can download and save free "<a href="http://www.videotoipadconverter.org/guides/wmv-to-ipad-converter.html">WMV to iPad Converter</a>" on your computer. You can click the "Open file " button to load files. If you want to delete files, you can click the "Remove" button besides the "Open file " button.<br /><br />Step 2: According to your different needs, you can click at the "Profile" area "..." button to customize your output videos. You can click the "down arrow" button to set the output format and click the "Output" area "..." button to set the destination folder. At the same time, you can preview the added files by click "Play" button on the left windows.<br /><br />Tips: From the above interface, you can see t he output settings, you can change the default settings, For example Video Bitrate, Frame Rate, Video Size, and Audio Bitrate, Sample Rate, Channels, and even Advanced Video Options, the video effect apply on all these settings. <br /><br />Step 3: At last, just click the "Convert" button to start converting WMV to iPad.<br /><br />Aftere a little minutes later, the conversion will be finished. Then you can share your WMV video with your friends on your ipad now.For Mac user, you can use this professional <a href="http://www.ipad-converter-mac.net/">iPad converter Mac</a> software.<br /><br />
on Oct 25, 2010 | Computers & Internet
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Sep 15, 2014 | Apple iPad Tablets & eReaders
Price of cheaper priced ipads
Could you be more specific. Taking a wild guess if you are looking at for a cheaper priced iPad then Apples own refurbished site is a great place to start. Ebay is another place if you want to sample the used market. As a precaution make sure you get a model with enough storage, 16gb IMO is too small, a few books, a game or three and some songs and now you're stuck with not enuff storage and no means to upgrade without buying another model.
Sep 01, 2014 | Apple Computer Apple Bretford PowerSync...
Tip
How to Convert Video to iPad for Mac?
Now the new iPad is a much better device to videos on than any previous version of the iPod and iPhone, there are many people curious about how to get their video files into a format that the iPad can play. Well, there are a number of ways to do this, one of these programs is called the Mac iPad Video Converter Software.The program offers an excellent job for converting and editing videos for making them playable on the video iPad. Below is the step-by-step guide about how to convert different video into iPad-ready formats on Mac. Video to iPad Mac Converter Various Settings:
Adjust video image effects by setting video brightness, contrast, saturation, applying a built-in video effect and normalize sound levels of DVD.
Support video output settings, including resolution, frame rate, encoder, bit rate and audio output settings, including sample rate, channel, encoder and bit rate.
convert-video-to-ipad-mac.gif Step 1: Free download the Mac iPad Video Converter software, install and launch it on your Mac.
Step 2: Click "Add Files" button to load any Video format file. You can add more files for batch conversion. To merge files, you can check before the item "Merge into one file".
Step 3: Choose an output format for your converted Video to iPad Mac files in the profile option. Find a document to store your output file.
Step 4: You can click "Convert" button to start conversion progress. Because of the super features, this conversion only cost you a few seconds.
video-to-ipad-mac.gif This professional Video to iPad Mac Converter is specially design for Apple iPad, aiming to enable iPad users an exquisite experience of viewing video entertainment on your iPad’s largescreen. If you find yourself saving and converting video on a regular basis, then spend a few bucks and get the software. Also if you want to rip and convert DVD movie to iPad, there’s another tutorial that you might like: How to rip and Convert DVD to iPad on Mac.
more information:video converter ipad,convert video to ipad,dvd to ipad mac
on Jun 13, 2010 | Computers & Internet
Tip
Mac Blu-ray to iPad Converter - Best iPad Blu-ray Converter for Mac users Best...
Best iPad Video settings
Follow the optimal settings to get excellent playback quality.
Video:
Codec: H.264
Size: 640*480 or 1280*720
Bitrate: 2500kbps
Frame rate: 30fps
Audio:
Codec: aac
Sample rate: 48khz
Bitrate: 160kbps
Channels: Stereo
Pavtube Mac iPad Blu-ray Converter v2.6 is a powerful tool specially designed for Mac users to rip, convert, backup and edit both Blu-ray and DVD movies. The source movie could be from Blu-ray disc, DVD, Blu-ray and DVD folder, DVD ISO and IFO file. The ripper could remove all the protections of Blu-ray and DVD movies , back up the movies to hard drive, rip and convert them into other popular audio and video formats to playback on your beloved portable devices such as iPad, iPod, iPhone, Zune, Blackberry, PSP, Creative Zen, Xbox 360, Apple TV etc. Besides, the M2TS files can be imported to Blu-ray Ripper for Mac and converted to compatible formats for editing in video editing software like iMovie, FCP, Avid etc.
Blu Ray Ripper for Mac features powerful editing functions and customization. You can trim and crop the video to any size and any length, adjust the video effect, replace the original audio with your favorite music, add watermark to make your video different. More specific video and audio parameters such as frame rate, bitrate, sample rate, audio channel are available for your enjoyment as well.
The lastest updates improved the program to capture any of the Blu-ray subtitles and audio tracks. Even 7.1 channels is available. You may also back up the whole Blu-ray disc/ DVD to hard drive with one click.
What's new
- Added the option of one-click Full Disk Copy, enabling users to make 1:1 copy of Blu-ray disc and DVD.
- Added support for Blu-ray disc of MKB v17.
- Improved the loading speed of Blu-ray disc/ folder.
- Added customized output formats for iPad.
- Refine the GUI to be more user-friendly, and apply Deinterlacing facility by default.
For Windows user: Windows Blu-ray to iPad Converter
Learn more: Best iPad video conversion tools
on May 12, 2010 | Cell Phones
WILL APPLE FIX MY IPAD AIR IF IT DOESNT CHARGE FOR FREE
Apple only fixes it's products for free during guarantee period (mostly 1 year, 2 years with Apple Care Protection Plan), but before you send it to Apple check your charger, you need at least a current of 2Amps. If this is ok, check if the charger can charge other devices. If yes, go to a store selling iPads and check if you can charge your iPad with the charger of one of the sample products.
Apr 11, 2014 | Microsoft Tablets & eReaders
Brookstone iconvert not saving getting errors
On iPad goto Settings -> Privacy-> Photos
Turn on iConvert Scanner
Dec 30, 2012 | Brookstone Scanners: iConvert Photo...
Tip
Convert Blu-ray and standard DVD to iPad, iPad Blu-ray disc/standard DVD Ripper...
Because of its 9.7-inch 1024×768 high resolution multi-touch screen, iPad is convenient and comfortable for users to read newspapers, magazines, books, view photos, experience the web, touch emails, and watch any kind of video, from HD movies and TV shows to podcasts, music videos and more. Also because there is no distracting keypad or buttons on iPad, you will totally concentrate on this big screen, and feel completely immersed in whatever you’re watching. You can imagine how wonderful it is to watch your HD Blu-ray and DVD movies on this little gadget. Are you ready to do so? If so, this article will give you a solution to the problem of how to convert Blu-ray and standard DVD movies to a compatible format with iPad. If you are looking for such a solution, just read on to get the detailed steps and the optimal playback settings for iPad.
The software you will need is Pavtube Blu-ray to iPad Ripper(for Mac: Mac Blu-ray to iPad Ripper).
Before that, go to see the iPad supported video formats as below:
H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
Well, it is obviously that Blu-ray and DVD movies are out of the above categories, and then please follow the following guide to do format conversion before your playback.
Step 1: Add Blu-ray or DVD movies into this program
Click “DVD Rom”, “DVD Folder”, or “IFO/ISO” icon to load Blu-ray or standard DVD movies.
Step 2: Select subtitle and audio track
Click on the dropdown list of “Subtitle” and “Audio” respectively to select your needed subtitle and audio track.
Step 3: Select “iPad” as output format
Click the pull down menu at the end of “Format” to select an output format for iPad. Here I choose “iPad Video MPEG-4 (*.mp4)” for instance.
Step 4: Click “Settings” button to adjust audio and video parameters
You are allowed to adjust codec, aspect ratio, bit rate, frame rate, sample rate and audio channel in the popup window to optimize the output file quality. Following are the recommended settings to get best playback quality.
Video:
Codec: h264
Bitrate: 2500kbps
Frame rate: 30fps
Audio:
Codec: aac
Sample rate: 48khz
Bitrate: 160kbps
Channels: Stereo
Step 5: Click “Convert” button to start conversion.
Once finished, you can get the output files for your iPad via clicking on “Open” button effortlessly. Afterwards, connect your iPad to your PC, and then sync the videos to iPad via iTunes.
Learn more: Convert/rip DVD and HD Video to your iPod,iPad,iPhone
Portable Media Device
on Apr 29, 2010 | Computers & Internet
collect3 Beatwave Logo
77 people viewed this question
Top collect3 Apps Experts
Lesley Cameron
Lesley Cameron
Are you a collect3 App Expert? Answer questions, earn points and help others
