Question about Lascal Buggy Board Maxi Black
How do you take the wheels of lascal maxi buggy board
How do you remove the wheels?
Removing buggy board wheels
first move the red lock all the way out and then just pull the wheel - it won't come out easily but if you use some force...
Nov 23, 2012 | Lascal Buggy Board Maxi Black
Can you fit a buggy board to a quinny zapp xtra?
Hi
We would not recommend it.
The Zapp Xtra is a lightweight, short wheel base chassis and the addition of a buggy board may make it unstable and likely to tip. In addition please remember the maximum weight limit for the Zapp Xtra and do not exceed this with the combined weight of the 2 children. If you choose to use a buggy board Quinny do not accept responsibility for the performance of the Zapp Xtra or any damage done to the chassis caused by the buggy board.
Jul 16, 2012 | Quinny Zapp Xtra Travel System Stroller
How can I attach the car seat to mama& papas Zola buggy using adaptors?
Hi - Maxi Cosi don't produce the adaptors that put the Maxi Cosi carseat onto a chassis produced by another manufacturer. It would be the manufacturer of the buggy that you need to contact to ask them about fitting directions as they produce the adaptors.
Feb 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Can I but a buggy board for a quinny buzz 3?
hi yes you can the info is here (lascal buggy board)
http://www.buggyboard.info/page.php?buggy=237&page=maxi
Nov 16, 2010 | Quinny Buzz Three Wheel Stroller
Bebe confort loola wheels were to buy
I had pruchased a Loola Up buggy off of Ebay and the wheels are worn. I have just ordered a new set from Dorel. They are £9 per wheel (mine has double wheels at the back, this is classed as 1 wheel) £3.95 for delivery. They are in stock and should arrive within 14days.
Fab service.
Aug 30, 2009 | Baby Gear
Is the Lascal maxi buggyboard compatible with the Freestyle 4 wheeler?
It should be as it has extra connectors for different strollers.
Aug 05, 2009 | Quinny Freestyle 4 Marina Stroller
Need tyre for maxi cosy 3 wheeled buggy size 280 x 65 -203
contact www.dorel.co.uk customer services and they should be able to send you the tyre.
Jul 18, 2009 | Quinny Buzz Jogger
Maxi cosi car seat for a quinny buggy
Go to the Maxi Cosi website, choose your carseat model and there are Instructions online. It's a bit fiddly but once you've done it once or twice you'll find it easy.
Feb 24, 2009 | Maxi-Cosi Cabrio Red Flame Reflection...
Buggy board
You could try the Lascal KiddyBoard or BuggyBoard distributed by www.regallager.com . They may have enough specs on their website to confirm whether or not it will work with your Perego stroller.
Good Luck! from Moms Just Know
Oct 17, 2008 | Peg Perego Baby Gear
Lascal Buggy Board Maxi Black Logo
61 people viewed this question
Top Lascal Baby Care Experts
masud
masud
Tom Chichester
Are you a Lascal Baby Care Expert? Answer questions, earn points and help others
