Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
F31 fault code displayed
My fridge has started displaying an f31 fault code and is not dispensing water and has no information on the onscreen display.
  • 69 Answers
SOURCE: WASHING MACHINE WONT START UP AND DISPLAY FAULT
Fault 49 indicates Out of Balance fault- usually faulty microswitch. To access- disconnect from power, remove two screws at top rear to remove control panel. You will see large brown control board. Disconnect all wiring connections, taking note where they came from (they are keyed to only fit in correct slots, but is best to note positions anyway). Remove brown control board (held in by either one screw, or clip on right hand side) Underneath control board you will see a small microswitch with two wires on it- this is the Out of balance microswitch. Often the switch will be corroded, or the little button is stuck in. Replace microswitch- they are available from any good appliance parts shop, and you'll be back in business!! If in any doubt as to doing this yourself, call in the experts, as it is an easy repair for a tech, and you don't want to make an easy repair turn into something more expensive!!
Posted on Mar 09, 2010
  • 1382 Answers
SOURCE: U2 Fault cde displayed at start of wash cycle
The reason for U2 fault code in your dishwasher is due to the problem caused beacuse of loading. Check loading to ensure no items extend beyond the height of the drawer.
Posted on Apr 05, 2010
  • 3247 Answers
SOURCE: I have a 10 year old dishdraw (Model No DD601v2).
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Posted on Nov 26, 2010
SOURCE: Have fisher paykel drier model DE27CW1 -
http://www.technostation.com/user-guide-owners-manual/Fisher+%26+Paykel/Fisher+%26+Paykel+DE27CW1+Dryer
Ok, well unfortunately, this symptom doesn't tell us much :( Other than, the dryer is getting power? Obviously, it will NOT perform any functions. Now when something like this happens, it can, unfortunately,be one of many, many, many things. From, bad sensors, to spiked electronics. There is no real way to tell, unless specific symptoms, or Error codes are displayed. Accordingly, one will have to troubleshoot the entire system to find out exactly what is wrong, often the place to start is with the main Brain, and Sensors, however to do this one either must be experienced or obtain a service manual, as all units differ in operation and circuitry.
So, it is my professional advice to you, that you contact an F&P repair center, and ask that they call and give you a "Quote" as to the cost and type of repair required. This way at least one can get an idea of costings before making a decision as to what to do, repair or replace.
Many of my customers these days often prefer to put any larger amounts of money, that would be spent on a repair towards the purchase of a NEW unit, with a full warranty, now i also say this as I am aware of statistics that show to overall, a unit that has been repaired after a major failure, for whatever reason, will usually fail again within the next 12 - 18 months..
Posted on Apr 01, 2011
jnchahn
  • 252 Answers
SOURCE: Water sensing level not working on Fisher &
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
Posted on May 07, 2011
What does F31 mean on Frigidaire stove?
Thank you for your inquiry, friend!
Based off what you have described your Frigidaire range is displaying an F31 error code and you would like to know what it means. An F31 error code means a shorted probe connection. This could be a possible problem with your sensor probe, control panel, or probe connector. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue you may need to seek help from a professional technician for proper diagnosis and repair. Best of luck! -Matt
Aug 12, 2015 | Frigidaire Kitchen Ranges
/lfgf3014lbcwhat does f31 mean
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Mar 30, 2015 | Frigidaire Gallery 30" Self-Cleaning...
What does f31 error mean on fregidare gas range
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
F31 on my Frigidaire oven how do I fix it?
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
What do these codes mean E31-E41-E74-F31? can you help?
E31 = Shorted MAP cicuit sensor
E41 = Cam sensor circuit problem
E74 = Intermittent MAT
F31 = Display panels to BCM problem
This is to say if the vehicle is a 1991 Cadillac Deville
Then the Trouble Codes are as I listed above.
For future reference, the F is for BCM codes.
When entering the on screen diagnostics the display starts with one E for the PCM history, then E.E. for current. Same sequence follows for BCM codes starting with one F for history and F.F. for current ones
Mar 15, 2011 | 1991 Cadillac DeVille
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Starts beeping and F31 ERR flashes
Any F code error indicates a fault has been detected . Press Clear/Off to clear display and stop beeping then reprogram the oven. If the fault reoccurs record the fault number press Clear/Off and contact an authorized service agent. If you have access to the internet you can download a manual for this appliance go to www.frigidaire.com/support/support.asp
On the customer services page click on product manuals and you will be abe to download the manual and print it off.
Apr 21, 2009 | Frigidaire FEF352 Electric Kitchen Range
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
